2.0.9.110_canary_2024-11-09
This release is expected to progress to a stable release if no major blockers are found.
Unlike regular canary builds, this one has a major change in the build system, so it now runs on .NET8.
The builds are self-contained so Mono or .NET installations are not required to install.
For users running on builds prior to 2.0.9.x, this build will appear later as an update that requires manual installation.
Important changes from last Beta
- Updated to .NET8 with OS specific builds
- Using Kestrel as the API/UI server
- Mandatory password and new authentication scheme for server
- Settings database version updated to v8
- Backup database updated to v13
Please see list of known issues related to .NET8/Kestrel upgrade:
New tool to manage a running server
Due to incompatibility with duplicati_client a new tool is included, named Duplicati.CommandLine.ServerUtil.exe/duplicati-server-util.
Upgrade from v2.0.9.105
If you are upgrading from 2.0.9.105 please see the release notes from 2.0.9.106 for how to prepare the database.
Upgrades from other versions do not need special steps.
Downgrade backup database to v12
If you need to go back to v12, run these two SQL statements:
DROP INDEX "UniqueBlockVolumeDuplicateBlock";
UPDATE "Version" SET "Version" = 12;
Detailed list of changes:
- Minor updates to help text and option types
- Fixed an issue with file backend url on Windows, thanks @Jojo-1000
- Fixed a condition that could hang the trayicon on a crash
- Updated AWSSDK to latest version
- Fixed an issue with the AWS Secrets Manader provider stalling the load of settings
- Fixed Telegram notifications
- Added Agent MSI installer
- Updated Avalonia to the latest version to fix crash on Debian
- Added Agent PKG for MacOS
- Added CLI PKG for MacOS
- Added autolaunch for Agent Deb package
- Added option to let scripts create log entries
