Release: 2.0.5.112 (canary) 2021-01-20
2.0.5.112-2.0.5.112_canary_2021-01-20
Hightlights for this update:
  • Stability improvements
  • Error/help message improvemens
  • New Telegram backend
Detailed list:
  • Improved testing, thanks @warwickmm
  • Disabled legacy path handling, thanks @dferreyra
  • Bugfix for rclone backend (wrong paths), thanks @warwickmm
  • Bugfix for Sia backend, thanks @warwickmm
  • Fixed check for admin privileges on Synology, thanks @warwickmm
  • Defer uploading fileset to guard against missing blocks error, thanks @seantempleton
  • Fixed setting background-io-priority, thanks @achims311
  • Added Telegram backend, thanks @martikyan
  • Improved error logging on restore, thanks @barfoo4711
  • Improved commandline documentation, thanks @apreiml
  • Bugfix for run-script-before ignoring remoteurl, thanks @warwickmm
  • Better error messages, thanks @warwickmm
  • Code quality improvements, thanks @warwickmm
  • Fixed error that occured when using the dry-run option of purge-broken-files, thanks @warwickmm
  • Fixed logging errors when reading symlink targers, thanks @warwickmm
  • Fixed error in OpenStack configuration UI, thanks @warwickmm
  • Better error messages if webrequests return null, thanks @Gurthurb
  • Fixed password manager autofill, thanks @drwtsn32x
  • Updated CI GUI tests to work again and use Python3, thanks @warwickmm
  • Fixed an issue that caused restore errors when running in Docker, thanks @warwickmm
Note: RPM builds failed, so no RPM packages available.
Installed on Debian, updated a docker image, and installed on two Windows 10 systems so far… looking good…
Will you be able to fix that and get a release built? It and the Windows version are the only two I really care about although I do also have the Debian build installed.
I have uploaded an RPM build and fixed the script. New builds will include the RPM files.
Thanks for doing that, it’s installed without a problem will see what happens next scheduled backup
Nice! I hope this can be used for notifications :slight_smile:
I doubt it. A backend usually means a new Backup destination on backup configuration screen 2.
I see Telegram there now, but Advanced options for reporting are still, http, mail, and xmpp which
Duplicati and Telegram shows is enough for notifications to Telegram after some doing some setup.
I can confirm that this bug has been resolved. Dynamically changing the remote URL can be very useful, especially when using Duplicati on laptops. Thanks a lot for the fix!
