Release: 2.0.5.111 (canary) 2020-09-26
2.0.5.111-2.0.5.111_canary_2020-09-26
  • Support for Windows paths starting with “\?”, thanks @dferreyra
  • Improved performance of USN, thanks @dgehri
  • Improved performance for restoring, thanks @pcmind
  • Added support for filters with literals that would normally be treated as wildcards, thanks @dferreyra
  • Improved build and tests, thanks @warwickmm and @dferreyra
  • Switched to the new built-in .Net support for long paths, thanks @dferreyra
  • Fixed issues with the Docker images by including mono-complete, thanks @warwickmm
  • Fixed an issue with exporting passwords with url-encoding characters, thanks @warwickmm
  • Fixed an issue with displaying icons in the restore tree, thanks @warwickmm
  • Fixed a type that prevented a warning box from showing, thanks @warwickmm
  • Added Storadera as an S3 destination, thanks @warwickmm
Looks like the docker image didn’t get updated, still shows 2.0.5.110 as the latest.
There seems to be a problem building one of the ARM images, I will try to rebuild manually.
Another issue: a user reported getting “invalid characters in path” during startup. I suspect this is related to the fix Switched to the new built-in .Net support for long paths. If anyone else sees a similar problem, please let me know.
That is fixed now with a rebuild of the Docker images.
