Release: 2.0.4.7 (canary) 2018-12-13
2.0.4.7-2.0.4.7_canary_2018-12-13
Thanks for fixing this.
I’m a bit confused about the version numbers and update procedure:
  • The internal updater still doesn’t detect the new version. Running on 2.0.4.6. When I click Check for updates now, no new version is detected.
  • I want to download the zip version, because the internal updater doesn’t detect the new version, but there is also a 2.0.4.8 version, which seems to be identical:
Are the versions identical? Which version should be downloaded and installed?
/EDIT: sorry, missed drakar2007 's post, he already asked the same questions.
Ignore 2.0.4.7, I forgot to git pull so it is identical to 2.0.4.6.
Closing topic in favor of Release: 2.0.4.8 (canary) 2018-12-13.
