2.0.4.15-2.0.4.15_canary_2019-02-06
- Fixed an issue with backup of a Windows drive (without a path)
- Clarified the B2 user interface, thanks @Pectojin
I use B2 - happen to have a little further detail about what’s been clarified, just so I know what to look for when i upgrade?
It’s just when setting up authentication. We used to suggest that account id could be used but it can’t anymore.
It will ask for application id and application key now.
Is there something that needs to be done to already existing backups to b2 after this release?
Nope, the change is just cosmetic (i.e. the text no longer mentions account id).
Updating from 2.0.4.14_canary_2019-01-30 does not work at the moment for me, is this a known issue? The log states:
System.Net.WebException: The remote server returned an error: (502) Bad Gateway. at Duplicati.Library.Utility.AsyncHttpRequest+AsyncWrapper.GetResponseOrStream () [0x0004d] in <100e03489e9743ac982e946fb5db3979>:0 at Duplicati.Library.Utility.AsyncHttpRequest.GetResponse () [0x00044] in <100e03489e9743ac982e946fb5db3979>:0 at Duplicati.Library.AutoUpdater.UpdaterManager.DownloadAndUnpackUpdate (Duplicati.Library.AutoUpdater.UpdateInfo version, System.Action'1[T] progress) [0x0019c] in <6bdd0881190b412697e09f023959bd65>:0
Never mind, it just worked.
Should I go from beta to this canary release just to see if filters are working faster now? I am having “purge” commands taking unusually long time compared to “find” commands even when using the --no-auto-compact flag and also the same filters
