Release: 2.0.4.11 (canary) 2019-01-16
2.0.4.11-2.0.4.11_canary_2019-01-16
  • Many source code quality improvements, thanks @warwickmm
  • Added test percentage option, thanks @warwickmm
  • Fixed an issue with the log page not loading, thanks @LacunaSoftware
  • Updated the Mega API, thanks @Pectojin
  • Added tool to import a CLI backup into the server, thanks @warwickmm
  • Improved build tools to separate and simplify the GPG signing step, thanks @verhoek
  • Fixed a case where listing files backed up from a UNC path are not shown, thanks @mnaimann
  • Removed the unused file lookup table, thanks @Pectojin
  • Fixed an issue with the FTP backend where it would sporadically create files in the root folder of the server, thanks @balchen
  • Fixed quota reporting from GoogleDrive, thanks @warwickmm
  • Improved code quality, thanks @verhoek
Many thanks.
Will there be MSI release files for this? Can’t see them and also tried a check for updates on my Fedora server and nothing found. Sorry if maybe I just need to wait a bit longer.
There is a problem with the signing tools on this build, so I will make a new build with installers asap.
