Release: 2.0.3.9 (canary) 2018-06-30
2.0.3.9-2.0.3.9_canary_2018-06-30
  • Fixed an issue with dectection HyperV, thanks @mnaiman
  • Default to exclude the System State VSS writers, thanks @mnaiman
  • Fixed an issue where restores from the GUI would not autodetect blocksize and other parameters
  • Fixed an issue with VSS failing to map the paths
Thanks for the update. I always had to go back to 2.0.3.5, because with and after 2.0.3.6 came slow backups and tons of warnings (# of files?). Trying 2.0.3.9 now.
Oh well. As for “Datensicherung”, I have deleted amd recreated the database beforehand.
Warning while running [G] Datensicherung
Got 32875 warning(s)
Warning while running [Local] Android
Got 63844 warning(s)
If you are considering updating to 2.0.3.9 please note that we are looking into an issue that seems to be related --snapshot-policy being enabled causing MORE than the Source folders to be included in the backup (at least on Windows systems).
Not sure if I want, btw, an Update typically goes like this:
  • Download
  • Activate
  • “Cannot do, there’s jobs in Queue”
  • Start Server
  • Cancel job 1
  • Cancel job 2 (several seconds)
  • Cancel job 3 (takes minutes, Duplicati loves to count files before cancel)
  • Update, yay…
Not sure if that’s still an issue with newer versions but it sounds like the Cancel issue may be getting some attention…
IDK, I’m using yesterdays 2.0.4.17_canary_2019-04-11 and it does not interrupt on “Starting backup”. Which takes minutes on many files.
