Release: 2.0.3.11 (canary) 2018-09-05
2.0.3.11-2.0.3.11_canary_2018-09-05
  • Cleanup of async methods and naming, thanks @warwickmm
  • Added more non-compressible file extensions, thanks @ravisorg
  • Login password field is now auto-focused, thanks @ltGuillaume
  • Added more pause time options, thanks @bmendonca
  • Fixed filename comparer to support correct filename encoding, thanks @warwickmm
  • Changed the default filename query to fix reported slowdowns
  • Added additional experimental queries to possible speed things up even more with
My main PC’s backup runtime went from 1:30 - 1:40 (as in, just under 2 hours) in 2.0.3.10, to under 5 minutes (previous versions were averaging 5 or 6 minutes per run). Thanks for the fix!
Hello
I have updated three clients for the new version, so far 100%
