I had to force a cache reload, but now the live log height fix works
@drakar2007
It’s definitely working now =)
So the style fixes are good, and the changes to retention policy are also working as expected.
I have not tested the password fixes from @mnaiman. Have any of you tested them?
I just tested it and it didn’t work when I set the password and tried to login. But then I realized I had not updated on this machine.
It works perfectly if you remember to update
So… we include it in the experimental?
I mean, unless there are some command-line implications. I don’t personally use the command-line, so I haven’t tested it with the NOHOSTEDSERVER_OPTION and READCONFIGFROMDB_OPTION options.
I also tested the U functionality on a couple of backups and it’s looking good.
I replaced 1D:0s,7D:8h,4W:1W,10Y:1M with 1D:U,7D:8h,4W:1W,U:1M on a couple of backups sets with 20+ backups the past day and a couple the past 2-3 months. No backups were deleted (as expected since the policies are “equal”)
I also tried U:U just for fun, which also did not cause any of my backups to spontaneously combust.
Wait, is that a “keep forever” shortcut???
Yep
Might be a bit overkill to define it that way, but it proves a point
