Hello, I’m attempting to get Duplicati to work on my Qnap nas with Container Station 3.0. It’s perfect for my use case. For my destination, I can find my online backup bucket with Wasabi and the test connection works great. But for the life of me I can’t map a drive to backup anything beyond the container files.
Once I download Duplicati onto Container Station 3.0, I find: linuxserver/duplicati I install then do the following:
Under ADVANCED SETTINGS - NETWORKS I’m selecting CUSTOM - HOST
Under ENVIRONMENTS, I’m adding in:
Variable: PUID Value: 1000
Variable: PGID Value: 1000
Variable: TZ Value: Etc/UTC
Finding my absolute file path on Qnap is tricky, but on plex the folder where one of the files is stored is: /share/CE_CACHEDEV1_DATA/SHARED/ This is the folder I want to back up to Wasabi.
Under STORAGE I…
-‘add volume’ with Volume: config Container: /share/CE_CACHEDEV1_DATA/SHARED/
- ‘bind mount host path’ to host: /SHARED container: /source
Once I’m in Duplicati and open the file path - it doesn’t exist.
Any tips? I’m bad at CLI but I could try it if it’s the only option.
