Purge clarification
I have a backup that contains a database backup that’s not VSS compliant. As a result I create a zip file backup. These zip files get removed every 30 days and I retain the one from a month end. These zip files are in a duplicati backup source with other files and folders
As a result of backend storage issue I now want to purge the zip files that are no longer in the source from the duplicati backup.
From reading docs if i purge using *.zip it will remove all zip files from backups. Is this correct ?
Can I pass a list of files to purge from a txt file ?
Anyone have sql query that will list files in backup database but not currently in the current source ?
Ger
Yes, that is correct.
You can restrict what data is purged by using more path information in your wildcard. For example purging D:\path\*.zip would only delete zip files in D:\path or one of its subfolders.
Also you can limit the purge operation to only certain backup snapshot versions.
No, not that I’m aware of but if you can craft your purge request to be a more specific wildcard as I mentioned above, maybe that would help. Note that you aren’t limited to just one wildcard/include. You can do more than one in a single purge operation.
Might I suggest a better solution in the future is to separate these zip files so they are in their own backup job. That way you can use a different retention length and avoid needing to do any purges.
Lastly, please be very careful about running the purge command. Do it with a test backup set if possible so you can get familiar with how it works. The command line options must be crafted very carefully.
Rod
Thanks for the clarification. So as these zip files where in two directories I decided to remove them from backup and create a separate backup. And then purge. However when I try to purge I am getting error with orphan files.
Backup is running with no issue. I have tried to resolve the issue with the --auto-cleanup = true on a backup but no luck.
List-Broken-Files returns no broken file sets and repair database has no errors.
I had a look at the source and this is a list of entries in the file table that are no longer in a file set. In an effort to reduce this backup I had previously changed the rotation from keep-all to smart rotation. This ran without error and removed versions and was running without issue for several weeks. I suspect these entries are as a result of version removal.
Is there anyway to clear this error other then recreating the database ?
Ger
Nice job. Are you a developer? Duplicati team needs those, or even people who can look at source.
called
Its relative that I found with a text search for some of the above SQL to see if there was fixup code:
This is in DropFilesetsFromTable which is run in PurgeFilesHandler.cs (unfortunately after test) and
Can you either read more to see if you think just deleting a version will fix the bad reference, or test it, keeping in mind that this is highly experimental? I tried a tiny test backup, and it seemed to do the job.
Rather than delete any existing version, I backed up a new one just to delete it as version=0 (newest).
Good spot. Creating a new version and then deleting it removed the orphan files from the Database
Not a developer but as a System Admin I have goods scripting knowledge and can read code to debug at times
Will probably look to help on this project once I retire in the next year or so.
