I’ve spent a hole day trying to troubleshoot it, but without success.
I’m trying to use Oracle S3 Compatible Object Storage with Duplicati but i’m not able to do backups with it. it seems that it can connect and can list files, but cannot PUT files in it. Here’s a log of a backup operation and Verbose outputs.
This causes compatibility issues with S3-compatible object storage services that support v4 sigs but not streaming; for example, minio and Oracle Cloud Infrastructure.
Container for the parameters to the PutObject operation.
UseChunkEncoding If this value is set to true then a chunked encoding upload will be used for the request. Default: true.
Using s3-ext-signatureversion = 2 just make it not pass the connection test. It refuses to connect.
If it is Signature V4 Streaming doing this, i have no clue on what to do.
I’ve already opened a ticket with their support, and i’ll add all information you gave me to try helping them.
Thanks!
