Hi Everyone,
I’m having troubles trying to backup to Azure from a computer with W7, I fixed some of the problems that were appearing but can’t seem to find where this problem come from.
2020-07-09 16:36:53 -03 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
System.IO.FileNotFoundException: No se pudo encontrar el archivo ‘C:\Windows\TEMP\dup-ad9b11e5-5534-425b-9b9a-82c57b64de80’.
Nombre de archivo: ‘C:\Windows\TEMP\dup-ad9b11e5-5534-425b-9b9a-82c57b64de80’
en System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
en System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
en System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share)
en Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<b__0>d.MoveNext()
— Fin del seguimiento de la pila de la ubicación anterior donde se produjo la excepción —
en System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
en System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
en CoCoL.AutomationExtensions.d__10`1.MoveNext()
en Duplicati.Library.Main.Operation.BackupHandler.d__13.MoveNext()
en Duplicati.Library.Main.Operation.BackupHandler.d__20.MoveNext()
I have enough space (150gb free, blocks are 500mb, backup size is 360gb but never get’s past 2gb) there are no quotas configured for the drive. the window folder has the permissions for System, I’m running Duplicati as a service.
the process creates some temp files but stops.
I’m trying to backup a VHD created by windows server backup from another computer and copied to a drive in the windows 7 computer.
anyone has any idea what could cause this? or what thing could I check?
I’m completely lost at this point
Thank you in advance!
