Hi there,
So I set up the access to trial the new Duplicati portal a few months ago (Duplicati) and as part of that I enabled 2FA on the log-in for this.
Logging in is absolutely fine, password/2FA works like a charm.
The problem is, I am trying to change the 2FA app I use (leaving Authy) and need to change my security settings to presumably disable and then re-enable this setting (so I get ne QR code to scan using the new 2FA app).
I can’t for the life of me find the account or security setting that will allow me to do this - what am I doing wrong? Can someone guide me on how to do this, if possible please?
