Hi dear,
I tried to install the Synology package on my NAS server DS416 and It doesn’t work
Could you please to fix it up ?
Thanks a lot
Regards
Laurent.
Hi dear,
Thanks a lot
Regards
Laurent.
There are two known issues on Synology:
Thank for your reply quickly.
Enable packages is on and I’m the only admin.
The package has installed but when I launch It, It displays this error notification “Failed to launch package repair”
Regards
Laurent
There is some more information that could help here:
I just tried installing the beta package, and I saw the same message. After clicking “connect now” it started working.
I just re tried installing the beta package, same message, and after clicking “Connect now” It doesn’t start working.
Apart from Mono, do you have to install other packages like Apache, …?
No, you need Nginx, but that is used in DSM 6.0 and forward.
