Environment info
- Duplicati version: 2.0.5.114_canary_2021-03-10
Operating system: docker
duplicati/duplicati:2.0.5.114_canary_2021-03-10 - Backend: mega.nz
Description
I tried to use the destination backup mega.nz but:
- from web interface I follow the steps in the web wizard tool when I press “test the connection” after a while I receive: “Failed to connect: API response: ResourceNotExists”
- from cli (in docker container) i run:
duplicati-cli backup "mega://XXXXXXXXXXXX?auth-username=YYYYY@ZZZZZ.HH&auth-password=WWWWWWWWWWWWWWW" /backups/ --no-encryption --upload-verification-file=false --dblock-size=10mb --debug-output=true
I receive the message: Checking remote backup ... Listing remote folder ... but nothing happens
Problem
I tested mega login:
- with an empty user (no data inside) => NO PROBLEM work fast
- with a user with ~800Gb of data => PROBLEM docker exit code 137
Duplicati run correctly the operation.
I monitor the duplicati container with docker stats and iftop, I see that the process running and download correctly the data from mega api endpoint.
But after a while docker container terminate: Exit Code 137 => Indicates failure as container received SIGKILL (Manual intervention or ‘oom-killer’ [OUT-OF-MEMORY])
docker stats duplicati output:
CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
05b61e17ba72 duplicati 21.72% 2.797GiB / 7.772GiB 35.98% 281MB / 6.64MB 259MB / 94.2kB 30
After this docker stats output docker container terminate with exit code 137
Suggestions/Tests
Is possible to enlarge /usr/bin/mono-sgen process memory ?
I found this: https://stackoverflow.com/a/19375857 is this a possible solution?
I had modify the duplicati-server file in the docker images:
#!/bin/bash
EXE_FILE=/opt/duplicati/Duplicati.Server.exe
APP_NAME=DuplicatiServer
export MONO_GC_PARAMS=max-heap-size=500m,mode=balanced
export MONO_LOG_LEVEL=debug
exec -a "$APP_NAME" mono "$EXE_FILE" "$@"
to add MONO_GC_PARAMS to test if is possible to limit the amount of memory.
I tested also this configuration:
export MONO_GC_PARAMS="max-heap-size=1500m,nursery-size=128m,soft-heap-limit=600m"
I map the file in the docker-compose file as follow:
version: "3"
services:
duplicati:
image: duplicati/duplicati:2.0.5.114_canary_2021-03-10
container_name: duplicati
environment:
- TZ=Europe/Rome
volumes:
- ./data:/data
- ./backups:/backups
- ./source:/source
- ./duplicati-server:/usr/bin/duplicati-server
ports:
- 8200:8200
deploy:
resources:
limits:
memory: 2500M
reservations:
memory: 1500M
The results are the same.
Docker exit code is 137 after mega started to elaborate the downloaded information form api mega site.
