OS Specific Default Filters?
New user-- still coming up to speed…
I’m looking at this screen shot–
Ok. Looks like something I want to use.
But, when I look for this on my local install, I don’t see it. Is there an option I need to enable or something? I’m using OS X 2.0.2.1(on the default channel).
Thanks!
Those default filters were added to in a newer canary build, so they’re not available on the latest beta yet.
But you haven’t missed much, those buttons didn’t actually work until last canary release 2 weeks ago :slight_smile:
OK. Thanks for the info!
By the way, This will be working in the next experimental release, which is going to be out soon :slight_smile:
I’m not sure when the beta is coming as there are still some bugs that need to be addressed.
What are these “default” sets? I like to know what is excluded from my backup! Is it documented somewhere? Can the link to this documentation be added to the GUI?
I believe this is only visible in the code which you can see at GitHub. In this case you’d want to check the various “/// Creates xxx filters” sections to see what filters are added for each selection type.
I also wanted to clarify that the OP screen shot is for Duplicati versions older than 2.0.3.5. For 2.0.3.5 and later it’s now merged into the Filters type selector.
