Hello,
after this topic Almost Constant Connection Loss on Upload Verification , I think I’d need an option to have a few seconds delay between the end of the upload and the start of its verification.
Thanks to consider this request !
Hello,
Would you see this as one of these, or something else?
For my current case, I think the 3) would be the best , as this would avoid to stall every time.
So you’re thinking a single pause-then-retry and let it fail like it does now if the file still isn’t reported as being there after that one retry?
Yes, that should do the trick, thanks !
Technically, it’s a “pause-then-try”, though…
