you can set up backup when you turn on your computer?
thank
Welcome to the forum!
What operating system are you using?
On Windows, the installer defaults to running Duplicati when the user logs in.
Hi , i use w 10 pro, in planning options see only set for day/week/month/year, instead I would like the backup to start only when I turn win10 on or off
thank
I understood everything, I had not grasped the concept well
If you only want the backup to run when you turn on the computer, it may require the use of a different scheduler. The one built in to Duplicati doesn’t have a trigger for that type of event.
You most certainly cannot do a backup at the time you request your computer to turn off. Windows expects programs to close quickly after issuing a shutdown, and Duplicati wouldn’t have time to do what it needs to do.
