After many problems which repairing & deleting and recreating the database failed to cure, I got fed up and deleted all backup data (it is a sub-set of data also backed up elsewhere) and imported the job without metadata; and it still fails and a repair/recreate (for the umpteenth time gives):
“Recreated database has missing blocks and 1 broken filelists. Consider using “list-broken-files” and “purge-broken-files” to purge broken data from the remote store and the database.”
How can this be, it was a new backup with all data deleted on the remote end (I checked)!!?? And I cannot find (how to run) the suggested options using the GUI.
Is Duplicati/OneDrive fit for purpose? If this was my main backup, I’d be having sleepless nights.
Duplicati - 2.0.4.16_canary_2019-03-28
