Good night!!.
I’m performing a 500GB backup for oneDrive, but it always shows an error. Error follows. Any possible solution?
System.AggregateException: One or more errors occurred. ---> System.AggregateException: An existing connection was forcibly closed by the remote host ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.Socket.EndReceive(IAsyncResult asyncResult)
at System.Net.Sockets.NetworkStream.EndRead(IAsyncResult asyncResult)
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext()
---> (Inner Exception #0) System.AggregateException: An existing connection was forcibly closed by the remote host ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
---> (Inner Exception #0) System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()<---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
