I look for information about configuration of Onedrive Business “destination”:
I get my username adress and my paswword.
Where can I find “server + port adress” ?
Regards
Emmanuel
Hello!
I got this setup working (on Windows, not on Debian):
Rickard
I should clearify, the credentials work on Debian also, but the backup fails at a later stage, most likely not due to this…
Hi Rickard,
Thank’s for your reply.
I work on windows.
It doesn’t work !
Do you use OneDrive Business ? (or standard ?)
And when you speak about target, you mean “server + port” ? (see below)
Emmanuel
Thank’s Rickard,
I read you topic and I succed to make my first backup !
Regards
Emmanuel
Great!
I actually use both OneDrive Personal and OneDrive for Business, the personal is easier to use, but has less storage space (unless you use a paid option, and have Office 365 anyway).
