Seems other people also faced this issue, but there is no clear answer / solution for now.
After upgrading to v2.0.3.5-2.0.3.5_canary_2018-04-13, few of my backups received warning with:
Offset and length were out of bounds for the array or count is greater than the number of elements from index to the end of the source collection
I tried to Repair DB, and Rebuild DB, but the result was even worst, as backup failed after.
_See Problem with backup after canceling it - #7 by glaurent
As one of my backup set is small (4GB), I choose to delete all the files on the remote, and restart the backup from scratch … but the warning still occurs.
I will try to revert to a previous version, like v2.0.2.21-2.0.2.21_canary_2018-03-06.
But what happens with the latest Canary ?
Logs from a backup from scratch (well, logs from the 2nd backup in fact, but had the warning on the 1st run too).
DeletedFiles: 2
DeletedFolders: 0
ModifiedFiles: 34
ExaminedFiles: 40272
OpenedFiles: 37
AddedFiles: 3
SizeOfModifiedFiles: 50486821
SizeOfAddedFiles: 40858907
SizeOfExaminedFiles: 5192085871
SizeOfOpenedFiles: 91541731
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults:
DeletedFileCount: 0
DownloadedFileCount: 0
UploadedFileCount: 0
DeletedFileSize: 0
DownloadedFileSize: 0
UploadedFileSize: 0
Dryrun: False
MainOperation: Compact
ParsedResult: Error
EndTime: 02/05/2018 08:26:37 (1525263997)
BeginTime: 02/05/2018 08:26:36 (1525263996)
Duration: 00:00:00.2971280
Messages: [
2018-05-02 08:25:59 -04 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2018-05-02 08:25:59 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2018-05-02 08:26:00 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (146 bytes),
2018-05-02 08:26:30 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bc03f1b04c9aa4632a89b6570c422c37a.dblock.zip.aes (48,19 MB),
2018-05-02 08:26:35 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bc03f1b04c9aa4632a89b6570c422c37a.dblock.zip.aes (48,19 MB),
Warnings: []
Errors: [
2018-05-02 08:27:17 -04 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20180502T032710Z.dlist.zip.aes,
2018-05-02 08:27:58 -04 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-i623316c958ec4cdaaff6cbc5cebf44cc.dindex.zip.aes,
2018-05-02 08:28:38 -04 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-bb2acf03d9ee349dab18d764f51cba802.dblock.zip.aes
BackendStatistics:
RemoteCalls: 21
BytesUploaded: 52996759
BytesDownloaded: 0
FilesUploaded: 3
FilesDownloaded: 0
FilesDeleted: 1
FoldersCreated: 0
RetryAttempts: 12
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 148
KnownFileSize: 3754134900
LastBackupDate: 02/05/2018 08:25:59 (1525263959)
BackupListCount: 2
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
ParsedResult: Error
Messages: [
Warnings: []
Errors: [
DeleteResults:
DeletedSets: [
Item1: 1
Item2: 02/05/2018 00:11:05 (1525234265)
Dryrun: False
MainOperation: Delete
ParsedResult: Error
Duration: 00:00:00.9124560
Messages: [
Warnings: []
Errors: [
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20180502T032710Z.dlist.zip.aes
Value: [
Key: Error
Value: Offset and length were out of bounds for the array or count is greater than the number of elements from index to the end of the source collection.
Key: duplicati-i623316c958ec4cdaaff6cbc5cebf44cc.dindex.zip.aes
Value: [
Key: Error
Key: duplicati-bb2acf03d9ee349dab18d764f51cba802.dblock.zip.aes
Value: [
Key: Error
ParsedResult: Error
EndTime: 02/05/2018 08:28:38 (1525264118)
BeginTime: 02/05/2018 08:26:37 (1525263997)
Duration: 00:02:01.0386850
Messages: [
Warnings: []
Errors: [
ParsedResult: Error
BeginTime: 02/05/2018 08:25:59 (1525263959)
Duration: 00:02:39.2693870
Messages: [
Warnings: []
Errors: [
Rgds
