I have a problem with backing up to a NAS with Duplicati 2.0 Beta. I have created the backups on Windows Server 2016 with 6 jobs. The backup is done to a NAS drive. The disadvantage was that the backup only worked when a user is logged in. Since the backup should of course also work when no user is logged in, I installed the application as a Windows service and moved the job data from my user directory to the Duplicati installation directory. When the service starts, I can access the web interface and the jobs are available.
However, I can no longer select a network drive in the jobs. Only the local drives are available as destination. I then entered the path manually, this worked once, and I was able to complete the backup successfully, but one day later Duplicati can no longer find the path (it is however accessible and active). What could be the reason that the network drives I created are no longer displayed as the target. Even if I want to create new jobs, they are no longer selectable.
Error Message is always: The folder \10.7.67.19\Backup\ does not exist
