Since the update, a connection to the backup target OneDrive can no longer be established. Even creating a new AuthID does not solve the problem.
Hi @EcKY, welcome to the forum!
Are you still using version one of the OneDrive API? If so, then that’s probably the issue as Microsoft retired it last month - that’s part of what promoted this beta release as we wanted to get the v2 API out there for people to use.
You should be able to change the Destination Storage Type to Microsoft OneDrive v2 (in step 2 of editing your job), get a new AUTH ID, and the backup should start working again.
Please let us know if that doesn’t work or if you’re already using v2.
Thank you very much.
My problem could be solved with it.
Cheers, Daniel
