Hi there, I dug through this forum searching for Error 401. I get this one every time I try to connect with Backblaze. I set the keyID as my B2 Application ID and the applicationKey as the B2 Application Key. I tried this and other combinations, generated a new Master Key and new Application Key. I just can’t get it to work.
Right now the error switched to “Failed to connect: Error: ConnectFailure (The requested address is not valid in this context)”. Hopefully someone know better than me, any help is highly appreciated!
Oh and I use (just installed) Duplicati 2.0.6.3 for macOS (12.0.1 to be exact). I also had to install MonoFramework-MDK-6.12.0.122.macos10.xamarin.universal.pkg (since I do use VS Code for other stuff and it was mentioned that this version plays nicely with VS Code).
First, forget the master key. Don’t use that with Duplicati, as it has access to everything in your B2 account. You want to generate an application key with access to the specific bucket you want Duplicati to write to.
I see you tried generating a new application key but you still had trouble. Maybe you didn’t put the values in the right spot?
Hi, thanks for you time and effort! I did exactly that and got the mentioned error messages. To be sure, I generated another application key, but the problem stays the same. Also, I really can’t find anything regarding this hint: “The requested address is not valid in this context”.
Ok, interesting… I don’t know if your issue has anything to do with Duplicati running on MacOS or not. Unfortunately I don’t have access to such a system to test. Perhaps one of the other members of our forum does.
these may all be used (via DNS) by using https://api.backblazeb2.com which is where API starts.
Just going there from a web browser, though, you should be redirected to Backblaze home page.
Okay, now this is strange. I tried the same setup as described in my original post but on my MacBook with M1 Chip. Duplicati Backups work flawlessly now and the connection via Cyberduck does as well. My iMac on the other hand still doesn’t get any connection. Not via Duplicati nor Cyberduck.
So it sound like a deeper and even more serious problem which I can’t demand any more help from you.
Thank you so much for your support and thoughts.
I’ll keep you posted whenever I find out what’s causing this issue.
