Randomly, an error occur that I can’t see any of my backups in the Web GUI.
The following errors are shown in the console:
Some cookies are misusing the recommended “SameSite“ attribute 119
Cookie “” has been rejected as third-party. main.js
Layout was forced before the page was fully loaded. If stylesheets are not yet loaded this may cause a flash of unstyled content. jquery.min.js:4:18306
GEThttps://duplicati.domain.com/img/progress-stop.png
[HTTP/2 404 Not Found 325ms]
GEThttps://duplicati.domain.com/img/progress-resume.png
[HTTP/2 404 Not Found 449ms]
GEThttps://duplicati.domain.com/img/pause.png
[HTTP/2 404 Not Found 572ms]
GEThttps://duplicati.domain.com/img/throttle.png
[HTTP/2 404 Not Found 582ms]
GEThttps://duplicati.domain.com/img/mainmenu/home.png
[HTTP/2 404 Not Found 451ms]
GEThttps://duplicati.domain.com/img/mainmenu/add.png
[HTTP/2 404 Not Found 575ms]
GEThttps://duplicati.domain.com/img/mainmenu/restore.png
[HTTP/2 404 Not Found 452ms]
GEThttps://duplicati.domain.com/img/mainmenu/resume.png
[HTTP/2 404 Not Found 566ms]
GEThttps://duplicati.domain.com/img/mainmenu/settings.png
[HTTP/2 404 Not Found 564ms]
GEThttps://duplicati.domain.com/img/mainmenu/about.png
[HTTP/2 404 Not Found 576ms]
GEThttps://duplicati.domain.com/img/mainmenu/logout.png
[HTTP/2 404 Not Found 578ms]
GEThttps://duplicati.domain.com/img/external-link-hover.png
[HTTP/2 404 Not Found 584ms]
GEThttps://duplicati.domain.com/img/resume.png
[HTTP/2 404 Not Found 536ms]
Error: data is null
notifyIfChanged@https://duplicati.domain.com/ngax/scripts/services/ServerStatus.js?v=2.0.6.1:189:13
longpoll/<@https://duplicati.domain.com/ngax/scripts/services/ServerStatus.js?v=2.0.6.1:214:36
f/<@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:120:182
$eval@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:134:493
$digest@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:132:9
$apply@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:135:269
l@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:87:152
F@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:91:188
Sf/</K.onload@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:92:221
EventHandlerNonNull*Sf/<@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:92:57
n@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:88:367
k/f<@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:86:69
d/<@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:19:437
e@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:39:156
d@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:19:358
Ac@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:20:151
Zd@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:18:464
@https://duplicati.domain.com/ngax/scripts/angular/angular.min.js:289:430
j@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:26925
fireWith@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:27738
ready@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:29532
I@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:29723
EventListener.handleEvent*n.ready.promise@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:29834
@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:29932
@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:207
@https://duplicati.domain.com/ngax/scripts/libs/jquery.min.js:2:212
angular.js:12330:17
Angular 22
jQuery 8
Error: data.data is null
reload/<@https://duplicati.domain.com/ngax/scripts/services/BackupList.js?v=2.0.6.1:45:29
angular.js:12330:17
Angular 22
jQuery 8
Error: state.BrowserLocale is undefined
loadSystemInfo/<@https://duplicati.domain.com/ngax/scripts/services/SystemInfo.js?v=2.0.6.1:125:21
angular.js:12330:17
@https://duplicati.domain.com/ngax/scripts/controllers/AppController.js?v=2.0.6.1:162:9
angular.js:12330:17
Error: resp.data is null
this.LoadMoreData/</<@https://duplicati.domain.com/ngax/scripts/services/LogService.js?v=2.0.6.1:24:49
angular.js:12330:17
Angular 32
jQuery 8
Duplicati is running on Docker in Ubuntu 18.04 bionic, behind Reverse Proxy (Traefik)
). I’m in process to change it and will return with the result of the suggested changes soon.
