Need recovery advice after 2.3.0.0 issue: recreate found 36 broken filelists, purge dry-run fails
Hi everyone,
I’ve been without a functional backup since April, dealing with a cascading failure on a ~2TB backup set that started after a recent update.
I know from my recovery post last year that the default advice for major database issues is often “just start a new backup.” However, starting fresh means re-uploading (and losing) over 1TB of data with a second copy of a backup, which simply isn’t a practical option for me right now. I need to salvage this existing backup set, and I’m hoping to find out the safest next step from the current repair/recreate state.
The Environment
Normal Backup Setup:
  • Source: Windows 11, ASUS ROG Flow X13 (16 GB RAM) gaming laptop running the native Windows Duplicati client.
  • Destination: Raspberry Pi 5 (16GB RAM) acting purely as an SSH host, storing the data on an attached 4 TB ext4 disk.
  • Backup Size: ~2 TB, ~83,301 remote files, 341 filesets / versions.
Recovery Setup:
To isolate the issue and free up my laptop for work, I eventually moved the database recreate/repair attempts directly onto the Pi 5. These recovery attempts are running in a dedicated, isolated Duplicati Docker stack, testing copied databases with stable/beta images over the last few weeks.
The Timeline & Symptoms
1. The Initial Failure: April
On April 28th, a normal backup from my Windows PC failed with:
Could not load file or assembly 'Duplicati.Library.Interface, Version=2.3.0.1'
This seemed like a partial update or version mismatch on the Windows side.
2. Repair Attempts & Memory Blow-up
I attempted a database repair. For speed, I plugged the 4TB drive directly into a spare ThinkPad, but the repair repeatedly black-screened/crashed the machine. I verified this wasn’t just the ThinkPad by testing it on my main ROG Flow, which suffered the same issue.
Checking the logs, Duplicati was getting stuck on a massive SQLite query over FilesetEntry / File, requesting 60+ GB of virtual memory.
Workaround: I forced SQLite temp storage to disk using:
CUSTOMSQLITEOPTIONS_DUPLICATI=temp_store=FILE
The repair then completed without maxing out RAM.
Note for devs: this may be worth looking into as large-database SQLite temp-storage/resource behaviour, but it is not the main thing I need help with in this post.
3. The Recreate Phase
After the successful repair, the backup failed again stating:
Found 83301 remote files that are not recorded in local storage.
Since this is basically the entire backend, I treated the local DB as stale and moved to a full database recreate.
To do this without tying up my laptop, I moved the 4TB drive back to the Pi and set up the Docker test environment mentioned above. The recreate finished, but final validation reported 36 broken filelists, mostly spanning March 17 to April 20.
4. Purge Dry-Run Issues
I am currently testing purge-broken-files via the Docker test stack using copied DBs to be safe.
When I run:
purge-broken-files --dry-run
it successfully simulates the purge of all 36 broken filelists, but the operation still ends with a DatabaseInconsistency error.
The current stable-image dry run processed all 36/36 broken filesets, then failed final validation with examples like:
D:\MediaMonkey Backups\MM_20260314171509.zip, actual size 43733978, dbsize 26956762, blocksetid: 4049637
D:\Mixed In Key\10.0\AudioAnalysisCache3\1ed128c30a191e73861931fad9ebb3980.wfd, actual size 145673, dbsize 0, blocksetid: 4049643
D:\Mixed In Key\10.0\AudioAnalysisCache3\1ed128c30a191e73861931fad9ebb3981.wfd, actual size 145627, dbsize 0, blocksetid: 4049645
D:\Mixed In Key\10.0\AudioAnalysisCache3\3d12a17055aecb6410f3e5b747af02761.wfd, actual size 161481, dbsize 0, blocksetid: 4049649
D:\Mixed In Key\10.0\AudioAnalysisCache3\49aabdc27e233c764d5ffb81f6808f970.wfd, actual size 256579, dbsize 0, blocksetid: 4049651
... and 65 more. Run repair to fix it.
A repair --dry-run against a copied DB then refuses with:
ErrorID: DatabaseIsInRepairState
The database was attempted repaired, but the repair did not complete. This database may be incomplete and the repair process is not allowed to alter remote files as that could result in data loss.
Versions Tested During Recovery
The original Windows failure happened on:
  • 2.3.0.0 (2.3.0.0_stable_2026-04-14), but the error tried to load Duplicati.Library.Interface, Version=2.3.0.1.
On the Pi/Docker recovery side, I have tested:
  • duplicati/duplicati:beta
    • recreate completed but reported DatabaseIsBrokenConsiderPurge
    • purge-broken-files --dry-run failed final validation with DatabaseInconsistency
    • repair --dry-run failed with DatabaseIsInRepairState
  • duplicati/duplicati:stable
    • tested against copied DBs
    • purge-broken-files --dry-run processed all 36/36 broken filesets
    • final validation still failed with DatabaseInconsistency
    • repair --dry-run also failed with DatabaseIsInRepairState
I have not yet tested the latest canary on this recreated DB.
What I Need Help Deciding
At this point, I’m trying to choose the safest next recovery step. The current recreated database is in this state:
  • Recreate completed, but reported 36 broken filelists.
  • purge-broken-files --dry-run simulated all 36 purges.
  • Final validation still failed with DatabaseInconsistency.
  • repair --dry-run refuses with DatabaseIsInRepairState.
My main questions are:
  1. Given that state, is the recommended next step to run a real purge-broken-files, or does the dry-run validation failure mean that a real purge is unlikely to help?
  2. If a real purge is not recommended, what is the next supported recovery step? I’m more than willing to lose 70 files if that makes the backup set usable again - but even the fact that I want to purge them doesn’t bypass the current blocker.
  3. Does CUSTOMSQLITEOPTIONS_DUPLICATI=temp_store=FILE remain a reasonable workaround for large repair/recreate operations, or is there a newer recommended setting/version for this?
I have the backend data, recreated DB copies, and logs ready. I’m happy to provide specific command outputs or database logs if it helps track down where the logic is failing.
Thanks in advance for any help salvaging this. The frustrating part is that the apparent answer is acceptable to me - purge the broken files/filelists - but the current validation/repair-state loop is preventing me from getting to a usable backup set.
Just bumping this thread as I’m still completely stuck and could really use some guidance.
To summarize the blocker: I successfully completed the rebuild and isolated the dodgy files, but Duplicati won’t let me purge them because it’s caught in a validation/repair-state loop.
I’m highlighting this again because my system has been without a functional backup for months now. This is unfortunately feeling a lot like the Database Restore Takes Over 5 Days issue I ran into last year. During that incident, the pushed update changing the default block size from 100KiB to 1MiB triggered consistency errors and left me without a backup for almost two months.
With the 2.3 update seemingly triggering another cascading failure, I am once again pushing 8 weeks in the dark. I just need to know if there is a way to forcefully bypass this repair state or force the purge to execute so I can get back to a safe, working baseline.
Any technical workarounds to get this backup set functioning again would be hugely appreciated!
Update: I eventually recovered the backup
Despite the radio silence, I wanted to close the loop because this thread has now helped another user experiencing the same SQLite memory problem.
The immediate memory workaround was:
Without that setting, Duplicati’s repair validation caused Duplicati.CommandLine.exe to consume around 66–68 GB of virtual memory. I reproduced this on two different Windows computers. With SQLite temporary storage moved to disk, the heavy repair operation completed without exhausting memory.
Recovering the backup still required considerably more work:
  • Several full database recreates, each taking multiple days.
  • Identifying 36 damaged restore points containing broken filelists.
  • Archiving and then deleting those 36 affected versions.
  • Fixing one dangling BlocksetEntry relationship that made 37,054 empty files appear to have a 1 MiB block.
  • Running database consistency checks, remote tests and representative restores.
  • Comparing a restored file against its original SHA-256 hash.
  • Finally completing a real backup on 20 June 2026.
The repository was ultimately made usable again, but this was not a normal or realistically supportable recovery process for most users.
This issue is relevant again because another user has now reported repeated OOM failures during delete/cleanup and database rebuild. They tried the same temp_store=FILE workaround and went from 16 OOM kills to zero:
Release 2.4.0.0 discussion and independent reproduction
The maintainer’s response indicates that this likely involves a runaway SQLite query and may be related to the newer SQLite package.
I still think two improvements are particularly important for large repositories:
  1. Resumable database recreate, so a failure after several days does not require starting again.
  2. Safer SQLite temporary-storage behaviour for large databases, instead of allowing a maintenance query to exhaust all available memory.
I have retained extensive logs and database-analysis notes if they would help turn this into a reproducible issue.
