Hi guys, never had this issue before. A new server of ours are having below issue running on Windows Server 2008.
Blockquote
Failed: One or more errors occurred.
Details: System.AggregateException: One or more errors occurred. —> System.AggregateException: Could not find file ‘C:\Users\Administrator\AppData\Local\Temp\1\dup-c89ae731-e930-4359-a2a4-59e562a47bee’. —> System.IO.FileNotFoundException: Could not find file ‘C:\Users\Administrator\AppData\Local\Temp\1\dup-c89ae731-e930-4359-a2a4-59e562a47bee’.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Duplicati.Library.Main.Volumes.VolumeReaderBase…ctor(String compressor, String file, Options options)
at Duplicati.Library.Main.Volumes.BlockVolumeReader…ctor(String compressor, String file, Options options)
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<b__0>d.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext() --- End of inner exception stack trace --- at CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task) at Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result) at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action1 method)
—> (Inner Exception #0) System.AggregateException: Could not find file ‘C:\Users\Administrator\AppData\Local\Temp\1\dup-c89ae731-e930-4359-a2a4-59e562a47bee’. —> System.IO.FileNotFoundException: Could not find file ‘C:\Users\Administrator\AppData\Local\Temp\1\dup-c89ae731-e930-4359-a2a4-59e562a47bee’.
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext() ---> (Inner Exception #0) System.IO.FileNotFoundException: Could not find file 'C:\Users\Administrator\AppData\Local\Temp\1\dup-c89ae731-e930-4359-a2a4-59e562a47bee'. File name: 'C:\Users\Administrator\AppData\Local\Temp\1\dup-c89ae731-e930-4359-a2a4-59e562a47bee' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at Duplicati.Library.Main.Volumes.VolumeReaderBase..ctor(String compressor, String file, Options options) at Duplicati.Library.Main.Volumes.BlockVolumeReader..ctor(String compressor, String file, Options options) at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at CoCoL.AutomationExtensions.<RunTask>d__101.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__12.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__19.MoveNext()<—
Blockquote
