I am running Duplicati on a ReadyNAS. I had email notifications working a couple of weeks ago, and then there was a firmware update for the NAS, which I think broke the email function (backup jobs appear to still be running). I have to admit I don’t really understand what this error message is telling me, I wonder if anyone has any suggestions. I apologize if this doesn’t format correctly. if it doesn’t work I’ll try to edit and format it better.
Nov 11, 2017 12:27 PM: Failed to send email: System.TypeLoadException: Could not load type of field ‘System.Net.Security.SslStream:provider’ (0) due to: Could not resolve type with token 01000047 (from typeref, class/assembly Mono.Security.Interface.MonoTlsProvider, Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756) assembly:Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 type:Mono.Security.Interface.MonoTlsProvider member:
{“ClassName”:“System.TypeLoadException”,“Message”:“Could not load type of field ‘System.Net.Security.SslStream:provider’ (0) due to: Could not resolve type with token 01000047 (from typeref, class/assembly Mono.Security.Interface.MonoTlsProvider, Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756) assembly:Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 type:Mono.Security.Interface.MonoTlsProvider member:”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:" at Duplicati.Library.Modules.Builtin.SendMail.OnFinish (System.Object result) [0x0065c] in <06fd36a55bfc46638699ea2b0b8a2358>:0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233054,“Source”:“Duplicati.Library.Modules.Builtin”,“TypeLoadClassName”:“System.Net.Security.SslStream”,“TypeLoadAssemblyName”:”",“TypeLoadMessageArg”:null,“TypeLoadResourceID”:0}
It is saying that it needs to a specific value from the library, but that value is not present. Since the library (System.Net.Security) is a core part of Mono, it suggests that the Mono version is broken (missing the field that should be there).
Mono is definitely broken. I ran “mono /data/Duplicati/Duplicati,CommandLine.exe help” and got pages of errors about bit loading signatures and unhandled exceptions. Then I tried reinstalling mono using the instructions I had found earlier and I’m getting this:
mono-devel : Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed
Depends: libmono-system-runtime4.0-cil (>= 2.10.1) but it is not going to be installed
Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed
Depends: libmono-system-web-services4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-cil-dev (= 5.4.1.6-0xamarin1+debian7b1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
As this is way outside my ability to fix, I think I’ll have to find another way of running Duplicati on my network. I’m not capable of handling something this complex every time they update the ReadyNAS software. What’s weird is that backup and restore both appear to be working, though I’m getting yellow warning boxes for every operation in the web GUI but there are no errors in the logs:
Warnings: []
Errors: []
I think I’ll look into moving my Duplicati installation to another system.
mono -V results in:
Mono JIT compiler version 5.4.0.201 (tarball Fri Oct 13 23:01:19 UTC 2017)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: normal
Notifications: epoll
Architecture: armel,vfp+fallback
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen (concurrent by default)
Thank you for your help. I have set up a new server and I am moving Duplicati to that machine. Installing Duplicati on a NetGear NAS is not a reliable platform because firmware updates tend to be unstable and break things. It’s a beautiful piece of hardware, but my goodness has it given me headaches. I am going back to using it strictly for storage and I’ll let the new server handle everything else.
If so, please feel welcome to reply to that how-to topic, explaining why you would not recommend installing duplicati on a ReadyNAS. That could save others from those headaches.
Personally, I am considering upgrading my ReadyNAS Ultra to OS6 (because mono doesn’t run on the old RAIDiator firmware) just ti be able to run duplicati. But it looks like it’s not worth the trouble?
In my experience the opposite is true. The OS (ReadyNAS OS6) is rock stable and well maintained. Updated recently to version 6.9.1.
BTRFS is the best filesystem for a NAS I can think of (love the shadowcopy feature). The ReadyNAS devices will auto-detect and auto-repair file system corruption (if a CRC check fails for a file, ReadyNAS will automatically restore the file from the last shadowcopy, which is from less than an hour ago, marks the blocks allocated by that file as non-usable and send you a notification by email about the recovery process). This makes ReadyNAS a rock solid device for storing important data.
I’m not a Linux guy, but managed to get Mono installed and created a small script to start Duplicati from a regular file share. Had some issues with reporting (SSL issues), but --accept-any-ssl-certificate solved this. Until now, I’ve had not a single problem using Duplicati on my ReadyNAS (5 backup jobs running daily, updated Duplicati and ReadyNAS OS multiple times).
Indeed. Backing up for almost a year on my ReadyNAS using Duplicati. The latest 6.8 OS version (V6.8.1) is from September 28, 2017. I guess I’ve updated Ready OS6 8 to 10 times from 6.6.x to 6.9.1. None of them did break Mono.
So in reply to @tophee as well, I actually used your guide to get things installed under 6.8 (I don’t recall which exact version; I’ve been running Duplicati on it since at least mid-2017). Thank you very much for putting that guide together, it was extremely helpful. It appears my experience was unique and I’ll chalk it up to bad luck.
I edited one of the lines in the installation guide @kees-z wrote to:
echo "deb http://download.mono-project.com/repo/debian jessie main" | sudo tee /etc/apt/sources.list.d/mono-xamarin.list
(Changed “wheezy” to “jessie”)
Then apt-get update, followed by apt-get -y install mono-devel, followed by a really long list (and wait) while mono got set up again, and now Duplicati.CommandLine.exe help returns no errors followed by the help text.
Thanks for reporting this. ReadyNAS OS6 is a customized version of Debian 8 (Jessie), so my article seems to be incorrect about this. Changed it in the howto article.
I don’t know if this was a wrong Copy/Paste action, or that I actually installed the Debian 7 version.
Does anybody know how to verify which Mono version is installed on my ReadyNAS (Wheezy/Jessie)?
Your original instructions worked perfectly for me; I wouldn’t have known to make this change until I went back again and tried to update mono, and when I did apt-get update I noticed everything except the mono project said “jessie” so I figured I would try it. I’m glad I was able to help. Would it be worth noting in the guide to suggest people do a “lsb_release -a” on the NAS to check which version of Debian is installed and update the mono line accordingly? I don’t know how often that changes though.
root@NAS:~# apt list mono-devel
Listing... Done
mono-devel/stable-jessie,stable-jessie,now 5.4.1.6-0xamarin1+debian8b1 all [installed]
N: There is 1 additional version. Please use the '-a' switch to see it
root@NAS:~# apt list -a mono-devel
Listing... Done
mono-devel/oldstable,oldstable 3.2.8+dfsg-10 all
I didn’t run the command before I upgraded; I’m learning as I go. I wonder if that 3.2.8 version is the Wheezy version, since I assume mono was never part of the ReadyNAS core installation.
Listing... Done
mono-devel/stable-jessie 5.4.1.6-0xamarin1+debian8b1 all [upgradable from: 4.2.1.102+dfsg2-6]
N: There are 3 additional versions. Please use the '-a' switch to see them.
Listing... Done
mono-devel/stable 5.4.1.6-0xamarin1+debian7b1 all
mono-devel/now 4.2.1.102+dfsg2-6 all [installed,upgradable to: 5.4.1.6-0xamarin1+debian8b1]
mono-devel/oldstable 3.2.8+dfsg-10 all
Does this mean that you are using the latest Mono version (5.4.1.6) and that I downloaded the latest version, but actually use an older version (4.2.1.102)?
If this is true, is it recommended to update to 5.4.1.6? I don’t have any problems with the current setup. If updating is recommended, how to do it? apt-get update && apt-get-upgrade?
I’ve finally upgraded Mono to 5.4.1.6. apt-get update / apt-get upgrade did not work, because the OS was complaining about public keys that could not be found. This must have been the reason that version 5 was downloaded, but never installed.
I’ve removed mono with apt-get remove mono-devel and apt-get remove --purge libmono*. Then I reinstalled mono with the commands described here (for Debian 8).
Everything seems to work fine, Mono 5.4.1.6 is installed and active. I was hoping that this would resolve another issue: email and http reporting doesn’t work, unless I supply --accept-any-ssl-certificate. This isn’t fixed with the fresh Mono installation.
After some digging, I found out that I have exactly this problem:
With the difference that backups (including reporting) work for me when I supply --accept-any-ssl-certificate.
Any suggestion how to get everything to work without the need to use accept-any-ssl-certificate?
