Hi all,
I’m a long-time Duplicati user and my backup configuration (15 machines, ~30 backup jobs) has become a hot mess. It’s time to reorganize all my backups and I’m trying to come up with the best scheme. I have two primary backup destinations, a local NAS and Backblaze B2 buckets. In my current setup, each system has an individual backup for each destination. I’m seeing that Duplicati can now send backups to multiple destinations by backing up to the first destination then copying the backup files to the additional destinations (please correct me if I’ve gotten that wrong). I have a few questions:
- Other than reduced complexity, is there an operational, cost, or security reason why I would do that over maintaining the individual backups per destination?
- Does Duplicati copy the backup files directly from Destination 1 to Destination 2, or does it read/download the files from Destination 1 locally, then upload them to Destination 2. In other words, are there network traffic considerations for one scheme over the other?
- If one of the multiple destination jobs fails, is the whole backup considered “failed” or do I get status on each individual destination?
- Has the Community reached a consensus on which is “better”, or under what circumstances would one be preferable over another?
- If I’m using the Duplicati Console to track backups, is each destination counted as a single “machine” or does each destination count as its own machine?
Any advice/assistance would be greatly appreciated. Thanks.
Steve
The docs confirm your description: the job writes to destination 1, then copies the same volume files to the other destinations after each successful backup (inline mode by default; interval and counting modes exist). The trade-off worth weighing is blast radius: the extra destinations hold exact copies of the same files, so a wrong retention setting or one bad run propagates to every copy, while separate jobs keep their own local databases and can use different passphrases. Each copy can restore on its own if destination 1 is lost, which is what makes a 3-2-1 scheme work in a single job. Does a failed copy to the second destination mark the whole backup as failed in the report, or does the job stay green with a per-destination warning?
Another thing I didn’t think about before: based on my research in reconfiguring my own backups, the block and dblock size settings may be different for local/NAS vs remote/cloud backups. In that case, duplicating the files between a local and remote storage may not be the most efficient way to process the files.
Your sizing point has a hard edge worth checking before reconfiguring: the extra destinations are not re-encoded, they hold exact copies of the files destination 1 already wrote, so one job can never carry two different block layouts - the cloud copy inherits whatever the local set was fragmented with. blocksize is also fixed once remote data exists, so retuning it means a fresh backup set. If you want small blocks on the NAS and larger volumes in B2, two jobs with separate dbpath caches is the only route, at the cost of scanning and compressing twice. Current defaults are 1mb blocksize (older builds used 100kb) and 50mb dblock-size, the latter documented as the knob for backends with a per-file size limit. When you re-sized for B2, was the driver the per-file upload limit and request costs, or how often compaction rewrites whole volumes?
Neither, strictly. I used this tool which I built based on various forum threads. (Apologies for the shameless plug)
What actually sets the cloud --dblock-size:
- A 200 MB starting point taken from forum convergence. B2 and other cloud users settled on roughly 150–200 MB. It’s an empirical number, not derived from any cost model.
- Upload speed bands: under 10 Mbps drops it to 100 MB, and 200 Mbps or more raises it to 500 MB.
- Daily download cap: holds the volume to about ¼ of the cap, because a verify or restore downloads whole volumes.
- Unstable connection: caps it at 100 MB.
Per-file limits only show up as a guardrail warning past about 100,000 backend files.
Your 1/4-of-cap heuristic runs into a 2.4.x wall worth testing before retuning a live job: dblock-size is now stored in the local database, and 2.4.0.104 canary refuses to change it on an existing backup - ‘which is not supported. Please configure a new clean backup if you want to change the parameter’ - and the report shows a decrease is refused too. kenkendk confirmed the unsupported-change check covers every option stored in the database, called it a side-effect of another fix, and said a later version will fix it; the workaround today is deleting the Configuration row with the bundled database-tool. So a speed-band retune on a live job means a brand-new job or a manual DB edit. Old volumes also just sit there: retention marks their blocks as waste and only a compact process rebuilds them into new volumes. Does your estimator assume a clean new set, or does it expect people to edit the database row on an existing job?
It assumes a clean new set. I’ve been using Duplicati for a long time and have always been “told” that --blocksize is immutable and --dblock-size is changeable. With that ingrained in my head, the calculator assumes you’re starting from scratch.
