Is it possible to have one installation of Duplicati on OS X and have it backup data of all users (so basically the /Users directory)? I looks as if it only backs up the data of the user that installed Duplicati.
If it’s possible, how do I configure it?
Thanks,
Gero
Hi @gerovermaas , welcome to the forum!
Yes. The easiest way to do that is to run Duplicati as a service / daemon instead of just the tray-icon.
If you read through this topic it should help you with the shift:
I’m looking to put together a how-to for shifting a Mac installation of Duplicati to a service, but the only stuff I’m finding (such as Running as a Service on Mac is so old it doesn’t work with current versions of MacOS…
Unfortunately, I’m super familiar with Macs either so I’m not sure how to build a current OS version supported .plist file to send to launchctrl (or even if such as thing is needed) - but I am willing to play around with stuff!
So if anybody has any suggestions on how to get …
