Hi all,
So currently, I have about 50GB of data backed up to Backblaze B2 from my NAS. It works like so:
- I have a NAS, which my computer mounts via SMB
- Duplicati runs on my computer, and backs the files on my NAS up via SMB, and uploads them to Backblaze.
I’ve been encountering the [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError] error, so I decided to instead run Duplicati directly on my NAS, realising I could run it inside Docker.
Problem is now I am trying to figure out how I can move the backup across to inside my NAS. The raw files are there, but this is a fresh Duplicati install with no configuration yet.
Can anyone suggest what I’ll need to do? Exporting the backup configuration from my computer seems a good first step, but then I wonder about the sqlite DB, does that need to come too? Is the sqlite DB file portable between an x86-64 machine and the armhf machine I am moving Duplicati to?
