More Pause Options
Two points of feedback on current pause options in the GUI–
  1. It would be great to have longer time delay options for pausing.
    3 hours, 6 hours, 12 hours, 24 hours would be very useful.
  2. I have been selecting Pause ‘Until resumed’ - unfortunately it seems that scheduled backups don’t resume the backup, so it just pauses until I manually resume. If that’s the intended behavior of that function, perhaps another option Pause ‘Until next scheduled backup’ would work nicely.
Thanks for the consideration!
Oooo - I like that one!
In case you’re interested in adding these items yourself, there’s also a topic about adding pause items to the tray-icon menu. :slight_smile:
https://forum.duplicati.com/t/add-pause-times-to-tray-icon-context-menu/577/8
Thanks for the support. I’m not sure I’ve got what it takes to make these changes myself but hopefully they will be considered by the devs going forward. I also like your suggestion about the context menu in the tray icon.
I like that as well. It would be helpful if you could create a GitHub issue to help us keep track of this feature request.
Thanks for that suggestion. All set: Feature request: More pause options in GUI including "Until next scheduled backup" · Issue #3102 · duplicati/duplicati · GitHub
