Minimum requirements for macOS
Great to se a new beta version released. I see there is a macOS 11.0 requirement for the latest 2.0.7.1_beta_2023-05-25 version. I’m not sure why this version specifically is required, but is there any way to work around this requirement and install on an older macOS version?
My specific scenario is on macOS 10.15, the version just before macOS 11.
Hello
I’m not sure about the requirement reason, it has to do with the toolchain used to generate the release. You can try to install the previous version and use the automatic upgrade, or download the .zip and just overwrite the files if the automatic upgrade does not work. Absolutely no warranty it will work correctly though.
