Dear all,
I use Duplicati on a Docker instance (version 2.0.6.3_beta_2021-06-17) and I experience the “Message has been altered, do not trust content” error from time to time. When this happens, the only workaround I’ve found is to recreate the backup which is basically not the best option.
I’ve seen this issue has already been reported by some users, but I did not see any solution so far. As explained the only one being to recreate the backup.
Here are the log content :
Failed: Échec du déchiffrement des données (phrase de passe invalide ?) : Message has been altered, do not trust content
Details: System.Security.Cryptography.CryptographicException: Échec du déchiffrement des données (phrase de passe invalide ?) : Message has been altered, do not trust content ---> SharpAESCrypt.SharpAESCrypt+HashMismatchException: Message has been altered, do not trust content
at SharpAESCrypt.SharpAESCrypt.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x00405] in <45c43198e80545aeabaa9b98839b4c7d>:0
at Duplicati.Library.Utility.Utility.CopyStream (System.IO.Stream source, System.IO.Stream target, System.Boolean tryRewindSource, System.Byte[] buf) [0x0003d] in <2a3ee711c7c04f6c957360f2cf183a7f>:0
at Duplicati.Library.Encryption.EncryptionBase.Decrypt (System.IO.Stream input, System.IO.Stream output) [0x00008] in <ecdfcb55bc4741b99f194bd4ca137df6>:0
at Duplicati.Library.Main.AsyncDownloader+AsyncDownloaderEnumerator+AsyncDownloadedFile.get_TempFile () [0x00008] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.CompactHandler.DoCompact (Duplicati.Library.Main.Database.LocalDeleteDatabase db, System.Boolean hasVerifiedBackend, System.Data.IDbTransaction& transaction, Duplicati.Library.Main.BackendManager sharedBackend) [0x00259] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.DeleteHandler.DoRun (Duplicati.Library.Main.Database.LocalDeleteDatabase db, System.Data.IDbTransaction& transaction, System.Boolean hasVerifiedBackend, System.Boolean forceCompact, Duplicati.Library.Main.BackendManager sharedManager) [0x003a2] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired (Duplicati.Library.Main.BackendManager backend, System.Int64 lastVolumeSize) [0x000a5] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <e60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0011c] in <e60bc008dd1b454d861cfacbdd3760b9>:0
Log data:
2021-09-24 13:15:57 +02 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00da9] in <e60bc008dd1b454d861cfacbdd3760b9>:0
Any insight would be so helpful !
Cheers
