I realise 1.34 is unsupported - but nevertheless I have a backup in Amazon S3 done with 1.34 that I need to recover from after a cryptolocker attack.
Duplicati can see the restore points, but if I try to either browse them or initiate a full restore I get the message:
“the restore operation failed: unable to parse filenames for the selected volumes”
I don’t get any other options to try and do a repair or what not.
I’ve searched everywhere for some documentation on this version but can’t find anything.
If I look at my S3 bucket manually I can see all the files (and they aren’t encrypted by duplicati).
Does anybody know whether or not I can manually download the files from AWS onto my PC, and then run some kind of commandline tool to go through these files and restore them?
cheers. The commandline restore version is throwing the same error. I have a feeling the files I have aren’t matching the files listed in the manifest.
It’s not the end of the world, I can run a single unzip command on the full zips (then I don’t have to figure out how to make the diff thing work) and they are still going back into their respective folders, so that’s better than nothing =)
