Hello,
On MacOS Duplicati fails to detect Mono. The script /Applications/Duplicati.app/Contents/MacOS/run-with-mono.sh attempts to look in a few locations and eventually fails.
The problem is it does not look in /opt/local/bin and hence does not find mono installed by Macports.
If I run the application this way:
MONO_BIN=/opt/local/bin/mono /Applications/Duplicati.app/Contents/MacOS/duplicati
then it successfully launches.
Would it be possible to also add checks for /opt/local/bin/mono during detection to accommodate MacPorts distributed Mono?
Thanks
