I recently updated to macOS 12.0.1 (Monterey). Right after booting up the first time, I got a message informing me that Duplicati would not work with future versions of macOS. I found a similar issue for a different app on the Apple developer forum, and the image of the message there is similar to the one I saw.
To clarify, backups are working fine with the macOS 12.0.1 (not tested restore). However, I wanted to flag this in case it creates future issues.
Could you click “Learn More…”? If it’s a public web page, you can post the link rather than screenshot it all
I don’t have a Mac, and when this initially came up there wasn’t any information search could find that fit…
This might need more volunteers with macOS who can help (especially if you have some developer skills).
Duplicati team is low on volunteers in general (any out there?), and might be especially low on Mac ones…
because a problem that no volunteer can even see is a problem that the volunteer can’t really investigate.
Duplicati is a community effort and is limited by what volunteer resources the community will provide to it.
Thanks for the tip! The more general Python script is utility-scripts/DuplicatiVerify.py. It looks at least largely Python 3 ready, as found by running 2to3-2.7 over it (per an article I found). Tool suggested one line deletion. Script header says “tested with python 2.7 & python 3.8”, but I don’t know what macOS’ complaint looks for.
In comparison, rumps.py which is macOS specific and launches the TrayIcon, seems old and needing lots.
might be newer than Duplicati’s version, but this needs more expertise. Any experts? Can you file an Issue?
If a daring enough macOS user wants to experiment with the conversion tool on rumps.py on their Mac, feel free to see if a conversion can avoid message while still keeping things going (save the old file just in case).
Thanks for the tip. That helps, but now I need someone with a Mac to do " How do we start to uncover what is calling Python 2?" to see if it’s just rumps.py. My method was to 7-Zip extract a.dmg, then I search for import which Python scripts often use. It’s possible I missed one. As there’s a way to know for sure, let’s try that one.
Alternatively maybe filing an issue will get the development team working on getting someone in to work this…
I think an issue is the best path. There’s compiled code at https://github.com/duplicati/duplicati/blob/master/Duplicati/GUI/Duplicati.GUI.TrayIcon/RumpsRunner.cs that might be rumps start, meaning there’s a bit of a chain to trace through. Might need to see if the original author can help with this.
I think an issue is the best path. There’s code at https://github.com/duplicati/duplicati/blob/master/Duplicati/GUI/Duplicati.GUI.TrayIcon/RumpsRunner.cs that might be the rumps starter, meaning that there’s a somewhat long path there, and the debugging technique that article suggested might not quite fit well.
