Long delay while deleting unwanted files
This seems like a long time to delete some files, even if they are big, since the deletion is happening in a remote Backblaze B2 server. Should just be a request for deletion, right?
May 1, 2024 5:57 PM: Deleted 2 remote fileset(s)
May 1, 2024 5:56 PM: Backend event: Delete - Completed: duplicati-20240201T120002Z.dlist.zip.aes (222.16 MB)
May 1, 2024 5:56 PM: Backend event: Delete - Started: duplicati-20240201T120002Z.dlist.zip.aes (222.16 MB)
May 1, 2024 5:56 PM: Backend event: Delete - Completed: duplicati-20240131T120002Z.dlist.zip.aes (223.92 MB)
May 1, 2024 5:56 PM: Backend event: Delete - Started: duplicati-20240131T120002Z.dlist.zip.aes (223.92 MB)
May 1, 2024 3:40 PM: Deleting 2 remote fileset(s) …
Without more information I can only guess. What database blocksize are you using? Does this backup keep a lot of past versions?
I have seen in the past instances where if the database is very large - typically encountered when used with a small blocksize, or a backup that has a large number of past versions, certain operations can take a long time to complete.
I have most often run into this problem during the Compaction operation, which also shows up under the heading “Deleting Unwanted Files”.
There’s some SQL. Example below, but this is a pretty small backup. Your dlist files are 250 times my size.
2024-04-25 06:34:32 -04 - [Information-Duplicati.Library.Main.Operation.DeleteHandler-DeleteRemoteFileset]: Deleting 1 remote fileset(s) ...
2024-04-25 06:34:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Fileset" WHERE "Timestamp" IN (1712831327)
2024-04-25 06:34:32 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Fileset" WHERE "Timestamp" IN (1712831327)  took 0:00:00:00.001
2024-04-25 06:34:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "FilesetEntry" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset")
2024-04-25 06:34:32 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "FilesetEntry" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset") took 0:00:00:00.143
2024-04-25 06:34:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "ChangeJournalData" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset")
2024-04-25 06:34:32 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "ChangeJournalData" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset") took 0:00:00:00.000
2024-04-25 06:34:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "FileLookup" WHERE "ID" NOT IN (SELECT DISTINCT "FileID" FROM "FilesetEntry")
2024-04-25 06:34:32 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "FileLookup" WHERE "ID" NOT IN (SELECT DISTINCT "FileID" FROM "FilesetEntry")  took 0:00:00:00.143
2024-04-25 06:34:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Metadataset" WHERE "ID" NOT IN (SELECT DISTINCT "MetadataID" FROM "FileLookup")
2024-04-25 06:34:32 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Metadataset" WHERE "ID" NOT IN (SELECT DISTINCT "MetadataID" FROM "FileLookup")  took 0:00:00:00.128
2024-04-25 06:34:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Blockset" WHERE "ID" NOT IN (SELECT DISTINCT "BlocksetID" FROM "FileLookup" UNION SELECT DISTINCT "BlocksetID" FROM "Metadataset")
2024-04-25 06:34:32 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Blockset" WHERE "ID" NOT IN (SELECT DISTINCT "BlocksetID" FROM "FileLookup" UNION SELECT DISTINCT "BlocksetID" FROM "Metadataset")  took 0:00:00:00.157
2024-04-25 06:34:32 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "BlocksetEntry" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset")
2024-04-25 06:34:33 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "BlocksetEntry" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset")  took 0:00:00:00.147
2024-04-25 06:34:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "BlocklistHash" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset")
2024-04-25 06:34:33 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "BlocklistHash" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset")  took 0:00:00:00.047
2024-04-25 06:34:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: INSERT INTO "DeletedBlock" ("Hash", "Size", "VolumeID") SELECT "Hash", "Size", "VolumeID" FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" AS "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash")
2024-04-25 06:34:33 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: INSERT INTO "DeletedBlock" ("Hash", "Size", "VolumeID") SELECT "Hash", "Size", "VolumeID" FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" AS "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash")  took 0:00:00:00.362
2024-04-25 06:34:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash")
2024-04-25 06:34:33 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash")  took 0:00:00:00.427
2024-04-25 06:34:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: UPDATE "RemoteVolume" SET "State" = "Deleting" WHERE "Type" = "Files" AND "State" IN ("Uploaded", "Verified", "Temporary") AND "ID" NOT IN (SELECT "VolumeID" FROM "Fileset")
2024-04-25 06:34:33 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: UPDATE "RemoteVolume" SET "State" = "Deleting" WHERE "Type" = "Files" AND "State" IN ("Uploaded", "Verified", "Temporary") AND "ID" NOT IN (SELECT "VolumeID" FROM "Fileset")  took 0:00:00:00.000
2024-04-25 06:34:33 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "Name", "Size" FROM "RemoteVolume" WHERE "Type" = "Files" AND "State" = "Deleting"
2024-04-25 06:34:33 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "Name", "Size" FROM "RemoteVolume" WHERE "Type" = "Files" AND "State" = "Deleting"  took 0:00:00:00.000
2024-04-25 06:34:40 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.BackendManager-RemoteOperationDelete]: Starting - RemoteOperationDelete
2024-04-25 06:34:40 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Started: duplicati-20240411T102847Z.dlist.zip.aes (941.22 KB)
2024-04-25 06:34:41 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Completed: duplicati-20240411T102847Z.dlist.zip.aes (941.22 KB)
How big is the backup, and do you ever get any other long delays? Is this consistent? If so maybe watch About → Show log → Live → Profiling. If timing is hard, I suppose you could try a Commandline delete or make a big log-file at profiling level to see if you hit some really slow SQL or something else not showing.
That does confuse people – probably should get its own phase, plus maybe a redesign to avoid huge task springing up occasionally. Some people prefer more time-consistency for their complete backup run times.
Because the original post look like a live log, any compact (slow or not) would be above the top line shown.
Not to hijack the thread, but I am in agreement. Long ago I advocated for being able to set a time limit on the Compaction operation. The places I use Duplicati typically have very low upload speeds (sub 10Mbps) and so I frequently end up with Compaction operations taking more than a day to finish.
It’s not uncommon for me to receive an alert from my monitoring system that “Duplicati job XXXXXX has not reported recently”, only to find out that everything is fine, it’s just been compacting for days.
To bring the thread back around to the original question, in the past I had run into a very similar problem. I had an older backup job that I had created using the default blocksize of 100KB. After a while, I had to abandon the job and recreate it because certain SQL operations were beginning to take unreasonable amounts of time.
