Hello all,
I am very impressed by Duplicati, but some questions came up:
Installation as a service, /localuser
I want to install Duplicati as a service on my Windows machine (me being quite experienced) and on the one of a friend (rather not experienced; also Windows). VSS will be switched on.
Question for both cases: Do I install the service as System user and leave it like that, or do I install it as System user and switch to a normal user with Adminstrator privileges (yes, this is not good…) via the Windows Adminitration GUI?
In the latter case: Should I pass the “/localuser” argument during service installation? I tried both and see no obvious difference. I also tried to pass my user name via the “/localuser” argument, but it didn’t change anything (perhaps the syntax was wrong, but there was no error message either).
So what is this argument used for anyway? -
-portable-mode or not?
Should I set this swich in the two cases above (experienced/non-experienced user)?
I have the feeling that I would prefer the database in a quite well defined location rather than deep in some user’s home directory but that may be misleading. Are there any pros and cons?
And just for interest:
–detached-process?
What the heck is that supposed to do? The documentation says it makes the program quit immediately and sends no output. Why is it there? -
BackendTester
What is the syntax for the BackendTester in case of OneDrive? This did not work:
Duplicati.CommandLineBackendTester.exeonedrivev2://[AuthID]@Backup
“Backup” is the path on my OneDrive. Username and password instead of [AuthID] didn’t work either. -
–auto-cleanup, --auto-vacuum?
I wanted to stay as close to a default installation as possible, but these options sounded too good. Are there any known issues?
Thank you very much for any help and for this great piece of software
Christian
