Local network drive with Mac OS X
Hi @ll,
I installed Duplicate first time and want to use a local network drive (WD MyBook Live) 192.168.1.15 as target. Is that possible an how?
thx in advance
Stefan
Welcome to the forum!
Out of the protocols this device supports, I think FTP is the only one that Duplicati also supports. You can give that a try.
Alternatively, if you have mounted the drive somehow on your Mac, it might be visible if you choose the “Local folder or drive” destination option.
I’m not a Mac guy so I can’t say for sure.
I have mapped it, but it is not visible.
