I am hoping for some help after spending way to much time trying to get this to work.
I have been using B2 with rclone since CrashPlan announced they would drop support for Linux. I would love to get an easier and more flexible GUI for B2 though. I went looking for options again and ran across Duplicati.
On the surface it looks like Duplicati is exactly what I was looking for… If I could get it to work. I have set up a new bucket on B2. Hopefully I will be able to connect to the ones I have up there already, but I thought I would test with a new one. I created a new backup in Duplicati and give it a name and password for AES. The name is the same as the bucket if that matters.
I then set the storage type to B2 and fill out the rest. Setting the bucket name, leaving the path blank and using my account ID and a newly created application key. Hitting test connection at this point give me a 401 - UnAuthorized error. If I chose the username and password under the advanced options the error changes to bad_auth_token.
So far, I have updated my version of Mono to 5.14.0.177 and have installed ca-certificates-mono and run cert-sync. I think that helped as before that I didn’t get either of these errors, just a failure to authenticate. I am not sure what else to try. It is now midnight so I thought I would leave this here and see if others have ideas.
Below are the stdout logs from the server. I restarted it after each install / cert-sync as well.
System.Exception: 401 - bad_auth_token:
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.AttemptParseAndThrowException (System.Exception ex) [0x000b5] in <744672e2da8444bdaaf10c5b0487d731>:0
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.get_Config () [0x00148] in <744672e2da8444bdaaf10c5b0487d731>:0
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.get_APIUrl () [0x00000] in <744672e2da8444bdaaf10c5b0487d731>:0
at Duplicati.Library.Backend.Backblaze.B2.List () [0x00011] in <744672e2da8444bdaaf10c5b0487d731>:0
at Duplicati.Library.Interface.BackendExtensions.TestList (Duplicati.Library.Interface.IBackend backend) [0x00000] in <b7a5128865b14f37a66544de6a7ae6fb>:0
at Duplicati.Library.Backend.Backblaze.B2.Test () [0x00000] in <744672e2da8444bdaaf10c5b0487d731>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x000b7] in <670b0e4a9ae144208688fcb192d20146>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x00091] in <670b0e4a9ae144208688fcb192d20146>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x0026e] in <670b0e4a9ae144208688fcb192d20146>:0
System.Exception: 401 - unauthorized:
Thank you for any and all help!
) before claiming that it works.
