Limit CPU usage?
Is there a way, or will there be a way, to limit CPU usage of Duplicati? When it’s running, it uses 99% of my CPU (granted, only one thread). There needs to be a way to limit it. Also, are there plans for multithreading?
As far as I know, Multithreading is on the wishlist, which will make Duplicati run smoother, but it’s unknown if/when it will be implemented.
As a workaround, you can use --thread-priority=idle to slow down Duplicati if another process needs processing time.
In Windows, you can also limit duplicati to use just one CPU core.
Actually we have a working version, but it is not yet merged into any build: https://github.com/duplicati/duplicati/tree/concurrent_processing
I experimented with some CPU throttling and I have sample code for it, but it has not been merged in. I can share it with whomever wants to look at it.
the thread configuration in duplicati did not help in my case on linux. However, cuplimit helps. Just run
cpulimit -l 50 -p $(pidof Duplicati)
somewhere to limit cpu usage to 50%. You might look more into cpulimit or cpu groups as an alternative.
Is this something that can be made dynamic enough to be used as a --run-script-before item as a functional bridge until official support gets added into the codebase?
this is the way I plan it to use. So far, I launch this command from the command line manually to study the effect.
I’d love a copy of that code if you don’t mind please!
You can get it from here:
