I keep getting these warnings about file size differences with every command.
Trying to repair:
~ » duplicati-cli repair /media/xxx
Enter encryption passphrase:
Listing remote folder ...
remote file duplicati-b62e6e68803d44e0b84e7679813d61524.dblock.zip.aes is listed as Verified with size 15597568 but should be 52338573, please verify the sha256 hash "Cw2hEUVWDx+mxiew2XXSbDon5pD5uUjM/NW5t14z9Zs="
remote file duplicati-b2c511300d0cf448986de4d1e300e5e21.dblock.zip.aes is listed as Verified with size 6029312 but should be 52345517, please verify the sha256 hash "dZejNnWQTqdMbTUWvU6d5WFKoWzyjiuqxisyXaSMxxE="
remote file duplicati-be9e654a75614473180e6545d5a60fd1d.dblock.zip.aes is listed as Verified with size 6291456 but should be 52339165, please verify the sha256 hash "bhMOPwBuyEGpCURrRoETKXczPEy6+EE5Ed6HWcpUQzE="
Downloading file duplicati-b62e6e68803d44e0b84e7679813d61524.dblock.zip.aes (unknown) ...
Failed to perform verification for file: duplicati-b62e6e68803d44e0b84e7679813d61524.dblock.zip.aes, please run verify; message: File length is invalid => File length is invalid
Downloading file duplicati-b2c511300d0cf448986de4d1e300e5e21.dblock.zip.aes (unknown) ...
Failed to perform verification for file: duplicati-b2c511300d0cf448986de4d1e300e5e21.dblock.zip.aes, please run verify; message: File length is invalid => File length is invalid
Downloading file duplicati-be9e654a75614473180e6545d5a60fd1d.dblock.zip.aes (unknown) ...
Failed to perform verification for file: duplicati-be9e654a75614473180e6545d5a60fd1d.dblock.zip.aes, please run verify; message: File length is invalid => File length is invalid
Update to Duplicati v2.1.0.2 detected, manual install required: https://duplicati.com/download
and trying to verify:
duplicati-cli verify /media/xxx
Downloading file duplicati-20241013T080102Z.dlist.zip.aes (169.80 MB) ...
Downloading file duplicati-iad97d24d7e704e7988ec9d36fa1b17b9.dindex.zip.aes (46.68 KB) ...
Downloading file duplicati-bdb86710d68bb4371a89802aa6540f4a8.dblock.zip.aes (49.99 MB) ...
Examined 3 files and found no errors
And then trying to purge broken files, the same thing:
~ » duplicati-cli purge-broken-files /media/xxx
Nothing happens, the warning keeps appearing.
What can I do?
I have looked through various forum posts, tried my luck with ChatGPT, but the cases seem to be very different and I don’t really know how I can “fix” my backup so that it stays reliable.
My current version is 2.0.8.1_beta_2024-05-07 and I know there’s an update to 2.1 and I will do that asap, but I’m afraid it will complicate things even further.
Update: Tried to run a backup, getting two (new) missing files now (and same warnings about different file sizes appear again):
"DeletedFiles": 100214,
"DeletedFolders": 11054,
"ModifiedFiles": 16050,
"ExaminedFiles": 2910050,
"OpenedFiles": 2760732,
"AddedFiles": 123448,
"SizeOfModifiedFiles": 11032405845,
"SizeOfAddedFiles": 19722326160,
"SizeOfExaminedFiles": 172906986421,
"SizeOfOpenedFiles": 160526963886,
"NotProcessedFiles": 0,
"AddedFolders": 10641,
"TooLargeFiles": 0,
"FilesWithError": 0,
"ModifiedFolders": 0,
"ModifiedSymlinks": 0,
"AddedSymlinks": 384,
"DeletedSymlinks": 397,
"PartialBackup": false,
"Dryrun": false,
"MainOperation": "Backup",
"CompactResults": {
"DeletedFileCount": 6,
"DownloadedFileCount": 0,
"UploadedFileCount": 0,
"DeletedFileSize": 157305630,
"DownloadedFileSize": 0,
"UploadedFileSize": 0,
"Dryrun": false,
"VacuumResults": null,
"MainOperation": "Compact",
"Interrupted": false,
"Version": "2.0.8.1 (2.0.8.1_beta_2024-05-07)",
"EndTime": "2025-05-11T10:31:47.54439Z",
"BeginTime": "2025-05-11T10:30:21.985796Z",
"Duration": "00:01:25.5585940",
"Errors": null,
"RemoteCalls": 476,
"BytesUploaded": 12303026259,
"BytesDownloaded": 0,
"FilesUploaded": 463,
"FilesDownloaded": 0,
"FilesDeleted": 8,
"RetryAttempts": 3,
"UnknownFileSize": 0,
"UnknownFileCount": 0,
"KnownFileCount": 8135,
"KnownFileSize": 214211432708,
"LastBackupDate": "2025-05-11T09:54:07+02:00",
"BackupListCount": 13,
"TotalQuotaSpace": 499981516800,
"FreeQuotaSpace": 153309347840,
"AssignedQuotaSpace": -1,
"BeginTime": "2025-05-11T07:54:07.218525Z",
"Errors": null
"DeleteResults": {
"DeletedSetsActualLength": 2,
"DeletedSets": [
"Item1": 4,
"Item2": "2025-03-01T11:56:00+01:00"
"Item1": 2,
"Item2": "2025-03-10T12:00:00+01:00"
"Dryrun": false,
"MainOperation": "Delete",
"CompactResults": {
"Dryrun": false,
"Errors": null,
"RemoteCalls": 476,
"FilesDeleted": 8,
"RetryAttempts": 3,
"Errors": null
"EndTime": "2025-05-11T10:31:47.544819Z",
"BeginTime": "2025-05-11T10:27:41.163034Z",
"Duration": "00:04:06.3817850",
"Errors": null,
"RemoteCalls": 476,
"FilesDeleted": 8,
"RetryAttempts": 3,
"Errors": null
"RepairResults": null,
"TestResults": null,
"ParsedResult": "Fatal",
"EndTime": "2025-05-11T10:32:17.996248Z",
"BeginTime": "2025-05-11T07:54:07.218519Z",
"Duration": "02:38:10.7777290",
"MessagesActualLength": 976,
"WarningsActualLength": 45,
"ErrorsActualLength": 3,
"2025-05-11 09:54:07 +02 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started",
"2025-05-11 10:03:02 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2025-05-11 10:03:03 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (7.50 KB)",
"2025-05-11 10:06:21 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b10c52cb639834b46bec8420ed022abe0.dblock.zip.aes (49.97 MB)",
"2025-05-11 10:06:26 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b10c52cb639834b46bec8420ed022abe0.dblock.zip.aes (49.97 MB)",
"2025-05-11 10:06:26 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ib8b55970291447a49db74776e97736cf.dindex.zip.aes (86.47 KB)",
"2025-05-11 10:06:26 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-ib8b55970291447a49db74776e97736cf.dindex.zip.aes (86.47 KB)",
"2025-05-11 10:06:32 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b06c2338e239440d4af8048b809ad2ec3.dblock.zip.aes (49.93 MB)",
"2025-05-11 10:06:32 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b462e86b3224647248eddbd23b183e60a.dblock.zip.aes (49.93 MB)",
"2025-05-11 10:06:34 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b06c2338e239440d4af8048b809ad2ec3.dblock.zip.aes (49.93 MB)",
"2025-05-11 10:06:36 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b462e86b3224647248eddbd23b183e60a.dblock.zip.aes (49.93 MB)",
"2025-05-11 10:06:36 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i64c31d5c5e2e4ff3b75066c6805c2208.dindex.zip.aes (61.11 KB)",
"2025-05-11 10:06:36 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i64c31d5c5e2e4ff3b75066c6805c2208.dindex.zip.aes (61.11 KB)",
"2025-05-11 10:06:36 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i78e4db59b2f04f38a0e0fd9de84d0828.dindex.zip.aes (79.43 KB)",
"2025-05-11 10:06:36 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i78e4db59b2f04f38a0e0fd9de84d0828.dindex.zip.aes (79.43 KB)",
"2025-05-11 10:06:37 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b4b3bc1adba69460f8f03f4db55777bb0.dblock.zip.aes (49.91 MB)",
"2025-05-11 10:06:38 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b4b3bc1adba69460f8f03f4db55777bb0.dblock.zip.aes (49.91 MB)",
"2025-05-11 10:06:38 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ic8b58ab20dbf4e7e9d46b62292e59e3e.dindex.zip.aes (58.58 KB)",
"2025-05-11 10:06:38 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-ic8b58ab20dbf4e7e9d46b62292e59e3e.dindex.zip.aes (58.58 KB)",
"2025-05-11 10:08:42 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b1578e45020cb4c2e9ef74daf25ae11a8.dblock.zip.aes (49.91 MB)"
"Warnings": [
"2025-05-11 10:03:03 +02 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-MissingRemoteHash]: remote file duplicati-b62e6e68803d44e0b84e7679813d61524.dblock.zip.aes is listed as Verified with size 15597568 but should be 52338573, please verify the sha256 hash \"Cw2hEUVWDx+mxiew2XXSbDon5pD5uUjM/NW5t14z9Zs=\"",
"2025-05-11 10:03:03 +02 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-MissingRemoteHash]: remote file duplicati-b2c511300d0cf448986de4d1e300e5e21.dblock.zip.aes is listed as Verified with size 6029312 but should be 52345517, please verify the sha256 hash \"dZejNnWQTqdMbTUWvU6d5WFKoWzyjiuqxisyXaSMxxE=\"",
"2025-05-11 10:03:03 +02 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-MissingRemoteHash]: remote file duplicati-be9e654a75614473180e6545d5a60fd1d.dblock.zip.aes is listed as Verified with size 6291456 but should be 52339165, please verify the sha256 hash \"bhMOPwBuyEGpCURrRoETKXczPEy6+EE5Ed6HWcpUQzE=\"",
"2025-05-11 10:03:16 +02 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /home/ [ redacted for privacy]
"2025-05-11 12:32:17 +02 - [Error-Duplicati.Library.Main.Operation.FilelistProcessor-MissingRemoteFiles]: Found 2 files that are missing from the remote storage, please run repair",
"2025-05-11 12:32:17 +02 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error\nRemoteListVerificationException: Found 2 files that are missing from the remote storage, please run repair",
"2025-05-11 12:32:17 +02 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed with error: Found 2 files that are missing from the remote storage, please run repair\nRemoteListVerificationException: Found 2 files that are missing from the remote storage, please run repair"
"RemoteCalls": 476,
"FilesDeleted": 8,
"RetryAttempts": 3,
"Errors": null
Running repair then gives this for both of the missing files:
{"ClassName":"Duplicati.Library.Interface.UserInformationException","Message":"Repair not possible, missing 3969 blocks.\nIf you want to continue working with the database, you can use the \"list-broken-files\" and \"purge-broken-files\" commands to purge the missing data from the database and the remote storage.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at Duplicati.Library.Main.Operation.RepairHandler.RunRepairRemote () [0x00ff1] in <9b99db820df3422db0aa96d4648dc7b1>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233088,"Source":"Duplicati.Library.Main"}
Once I purge them, I’m back to the different file size errors:
