Deployed Duplicate on an Unraid server.
Created first backup job and re-ran until it completed successfully, uploading to a S3-compatible cloud storage provider. The job backs up my own data stored on this server, as well as the containers I have running on this Unraid server too, i.e. their configs and other.
The job is configured to run weekly, but this fails.
If I try to manually run it, it also errors.
I am mostly confused because it has run successfully the first time. So I am not sure why it is now erroring.
These are the entries from the log file, under the “Warnings” section (note, not the “Error” section):
“Warnings”: [
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/Nginx-Proxy-Manager-Official/letsencrypt/live/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/Nginx-Proxy-Manager-Official/letsencrypt/archive/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/Nginx-Proxy-Manager-Official/letsencrypt/keys/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/Nginx-Proxy-Manager-Official/letsencrypt/accounts/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/portainer-ce/docker_config/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/portainer-ce/bin/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/portainer-ce/compose/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/portainer-ce/tls/”,
“2023-02-14 20:35:12 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/portainer-ce/certs/”,
“2023-02-14 20:35:38 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /source/appdata/rclone/rclone.conf”,
“2023-02-14 20:36:26 +00 - [Warning-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-FileAccessError]: Error reported while accessing file: /source/appdata/Nginx-Proxy-Manager-Official/letsencrypt/live/”
However, I do not want to go in a disrupt a container’s filesystem permissions. Particularly the containers in question, it is their SSL cert keys which typically have owner-only RW permissions only.
