Issues with OneDrive as backup source
When choosing OneDrive as the backup source, isn’t it possible to select the root folder of OneDrive? It only seems to work if I enter an explicit folder under “Path on Server”.
Without a path I get an error
BadRequest: Bad Request error from request
Hi @lmer, welcome to the forum.
That sounds like a bug.
Can you try with a / as the path?
Unfortunately, this does not work.
The “Test connection” button does not appear in this scenario.I remember reading that it might also be a security feature of OneDrive that you cannot connect to the root folder, but I currently cannot find the source anymore.
