Hello,
Recently, the backup tasks fails to backup ldf and mdf files.
”All Microsoft SQL Servers” is checked in the task.
Snapshot-policy is set to Required.
Duplicati Release : 2.2.0.3 (issue started with 2.2.0.1, upgraded later)
OS : Windows Server 2022, WU up to date, defender AV
Here are the warnings :
[Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-FileProcessingFailed]: Failed to process path: D:\PATH\TO\FILE\file.ldf
SQLiteException: constraint failed[Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-FileProcessingFailed]: Failed to process path: D:\PATH\TO\FILE\file.ldf
code = Constraint (19), message = System.Data.SQLite.SQLiteException (0x800027AF): constraint failed UNIQUE constraint failed: FilesetEntry.FilesetID, FilesetEntry.FileID
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQuery(IDbCommand self, Boolean writeLog, String cmd)
at Duplicati.Library.Main.Database.LocalBackupDatabase.AddFile(Int64 pathprefixid, String filename, DateTime lastmodified, Int64 blocksetID, Int64 metadataID, IDbTransaction transaction)
at Duplicati.Library.Main.Operation.Backup.BackupDatabase.<>c__DisplayClass15_0.b__0()
at Duplicati.Library.Main.Operation.Common.SingleRunner.<>c__DisplayClass3_0.b__0()
at Duplicati.Library.Main.Operation.Common.SingleRunner.DoRunOnMain[T](Func`1 method)
at Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.<>c__DisplayClass1_0.<b__0>d.MoveNext()
WS Instance was rebooted, the issue stays the same.
Obviously, the mdf/ldf files pairs are the most critical items of the backup task.
Any idea ? Thanks.
