I am using Duplicati on my Debian server for year to backup my files to a OneDrive (personal) folder. After an update to the latest stable (or even the latest Canary) version, I am not able to connect to destination anymore. Anybody also facing issues with OneDrive on Linux?
I tried to connect to OneDrive using a Windows 11 system and it is working normally.
In livelog there is this message:
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid
at System.Net.Security.SslStream.SendAuthResetSignal(ReadOnlySpan`1 alert, ExceptionDispatchInfo exception)
at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](Boolean receiveFirst, Byte[] reAuthenticationData, CancellationToken cancellationToken)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Duplicati.Library.OAuthHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
at Duplicati.Library.Backend.MicrosoftGraphBackend.SendRequestAsync[T](HttpRequestMessage request, CancellationToken cancelToken)
at Duplicati.Library.Backend.MicrosoftGraphBackend.SendRequestAsync[T](HttpMethod method, String url, CancellationToken cancelToken)
at Duplicati.Library.Utility.Utility.WithTimeout[T](TimeSpan timeout, CancellationToken token, Func`2 func)
at Duplicati.Library.Backend.MicrosoftGraphBackend.Enumerate[T](String url, CancellationToken cancelToken)+MoveNext()
at Duplicati.Library.Backend.MicrosoftGraphBackend.Enumerate[T](String url, CancellationToken cancelToken)+System.Threading.Tasks.Sources.IValueTaskSource<System.Boolean>.GetResult()
at Duplicati.Library.Backend.MicrosoftGraphBackend.ListAsync(CancellationToken cancelToken)+MoveNext()
at Duplicati.Library.Backend.MicrosoftGraphBackend.ListAsync(CancellationToken cancelToken)+System.Threading.Tasks.Sources.IValueTaskSource<System.Boolean>.GetResult()
at System.Linq.AsyncEnumerable.<ToListAsync>g__Core|424_0[TSource](IAsyncEnumerable`1 source, CancellationToken cancellationToken) in /_/Ix.NET/Source/System.Linq.Async/System/Linq/Operators/ToList.cs:line 36
at Duplicati.Library.Main.Backend.BackendManager.ListOperation.ExecuteAsync(IBackend backend, CancellationToken cancelToken)
at Duplicati.Library.Main.Backend.BackendManager.ListAsync(CancellationToken cancelToken)
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(IBackendManager backendManager, Options options, LocalDatabase database, IDbTransaction transaction, IBackendWriter log, IEnumerable`1 protectedFiles, IEnumerable`1 strictExcemptFiles, VerifyMode verifyMode)
at Duplicati.Library.Main.Operation.RepairHandler.RunRepairRemoteAsync(IBackendManager backendManager, CancellationToken cancellationToken)
at Duplicati.Library.Main.Operation.RepairHandler.RunAsync(IBackendManager backendManager, IFilter filter)
at Duplicati.Library.Main.Controller.RunAction[T](T result, IFilter& filter, Func`3 method)
at Duplicati.Library.Main.Controller.Repair(IFilter filter)
at Duplicati.CommandLine.Commands.Repair(TextWriter outwriter, Action`1 setup, List`1 args, Dictionary`2 options, IFilter filter)
at Duplicati.CommandLine.Program.ParseCommandLine(TextWriter outwriter, Action`1 setup, Boolean& verboseErrors, String[] args)
These issues occur with an existing backup configuration and also while creating a new one. I am using the default OAuth provider (Duplicati OAuth Handler)
Not sure, which certificate is causing the issue.
I am open to any suggestions ![]()
Thanks and BR Heinrich
