Hi, trying to repair a database that went corrupt but getting an error.
Listing remote folder ...
Mono.Data.Sqlite.SqliteException (0x80004005): Abort due to constraint violation
UNIQUE constraint failed: Remotevolume.Name, Remotevolume.State
at Mono.Data.Sqlite.SQLite3.Reset (Mono.Data.Sqlite.SqliteStatement stmt) [0x00096] in <03f5dc00126848489ffe244e568a5e02>:0
at Mono.Data.Sqlite.SQLite3.Step (Mono.Data.Sqlite.SqliteStatement stmt) [0x00046] in <03f5dc00126848489ffe244e568a5e02>:0
at Mono.Data.Sqlite.SqliteDataReader.NextResult () [0x00129] in <03f5dc00126848489ffe244e568a5e02>:0
at Mono.Data.Sqlite.SqliteDataReader..ctor (Mono.Data.Sqlite.SqliteCommand cmd, System.Data.CommandBehavior behave) [0x00051] in <03f5dc00126848489ffe244e568a5e02>:0
at (wrapper remoting-invoke-with-check) Mono.Data.Sqlite.SqliteDataReader..ctor(Mono.Data.Sqlite.SqliteCommand,System.Data.CommandBehavior)
at Mono.Data.Sqlite.SqliteCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x00006] in <03f5dc00126848489ffe244e568a5e02>:0
at Mono.Data.Sqlite.SqliteCommand.ExecuteDbDataReader (System.Data.CommandBehavior behavior) [0x00000] in <03f5dc00126848489ffe244e568a5e02>:0
at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader () [0x00000] in <fb434c75f80444cb80ba3a9212e0956f>:0
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteScalarInt64 (System.Data.IDbCommand self, System.Boolean writeLog, System.String cmd, System.Int64 defaultvalue, System.Object[] values) [0x00061] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteScalarInt64 (System.Data.IDbCommand self, System.Boolean writeLog, System.String cmd, System.Int64 defaultvalue) [0x00000] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteScalarInt64 (System.Data.IDbCommand self, System.Int64 defaultvalue) [0x00000] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Database.LocalDatabase.RegisterRemoteVolume (System.String name, Duplicati.Library.Main.RemoteVolumeType type, Duplicati.Library.Main.RemoteVolumeState state, System.Int64 size, System.TimeSpan deleteGraceTime, System.Data.IDbTransaction transaction) [0x000c5] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Database.LocalDatabase.RegisterRemoteVolume (System.String name, Duplicati.Library.Main.RemoteVolumeType type, System.Int64 size, Duplicati.Library.Main.RemoteVolumeState state) [0x0000d] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Operation.RecreateDatabaseHandler.DoRun (Duplicati.Library.Main.Database.LocalDatabase dbparent, System.Boolean updating, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+NumberedFilterFilelistDelegate filelistfilter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+BlockVolumePostProcessor blockprocessor) [0x0030e] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Operation.RecreateDatabaseHandler.Run (System.String path, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+NumberedFilterFilelistDelegate filelistfilter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+BlockVolumePostProcessor blockprocessor) [0x00037] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Operation.RepairHandler.RunRepairLocal (Duplicati.Library.Utility.IFilter filter) [0x000ba] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Operation.RepairHandler.Run (Duplicati.Library.Utility.IFilter filter) [0x00012] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass18_0.<Repair>b__0 (Duplicati.Library.Main.RepairResults result) [0x0001c] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x00007] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.Library.Main.Controller.Repair (Duplicati.Library.Utility.IFilter filter) [0x0001a] in <80402d19122441e2bd57fbfcc5267c40>:0
at Duplicati.CommandLine.Commands.Repair (System.IO.TextWriter outwriter, System.Action`1[T] setup, System.Collections.Generic.List`1[T] args, System.Collections.Generic.Dictionary`2[TKey,TValue] options, Duplicati.Library.Utility.IFilter filter) [0x00030] in <c47f7ad6ab9944308264c2287272a0ec>:0
at (wrapper delegate-invoke) System.Func`6[System.IO.TextWriter,System.Action`1[Duplicati.Library.Main.Controller],System.Collections.Generic.List`1[System.String],System.Collections.Generic.Dictionary`2[System.String,System.String],Duplicati.Library.Utility.IFilter,System.Int32].invoke_TResult_T1_T2_T3_T4_T5(System.IO.TextWriter,System.Action`1<Duplicati.Library.Main.Controller>,System.Collections.Generic.List`1<string>,System.Collections.Generic.Dictionary`2<string, string>,Duplicati.Library.Utility.IFilter)
at Duplicati.CommandLine.Program.ParseCommandLine (System.IO.TextWriter outwriter, System.Action`1[T] setup, System.Boolean& verboseErrors, System.String[] args) [0x00342] in <c47f7ad6ab9944308264c2287272a0ec>:0
at Duplicati.CommandLine.Program.RunCommandLine (System.IO.TextWriter outwriter, System.IO.TextWriter errwriter, System.Action`1[T] setup, System.String[] args) [0x00002] in <c47f7ad6ab9944308264c2287272a0ec>:0
I found some very old references to a similar problem and tried to delete my sqlite backup file, but nothing works. I also upgraded from the latest beta to v2.0.5.107-2.0.5.107_canary, but that didn’t make a difference. Not sure how to fix this. Do I have to delete my old backups?
